Same lighting for photography as video? at DVinfo.net
Photon Management
Old June 8th, 2004, 10:11 AM   #1
I have a Canon 10D I use for photos and I just bought a Canon GL2. Before the GL2, I was planning on buying some Alien Bees for lighting my photographs. Now that I have the GL2 it would make sense to buy lighting that I can use for both.
I know that flash photography is different than video, but what can I share so I can cut down on costs?
Michael Le is offline   Reply With Quote
Old June 8th, 2004, 10:22 AM   #2
Warden
Video needs continuous lighting, whereas stills can benefit from flash photography. If you want to share anything other than the light stands, soft boxes, umbrellas etc. then you'll need to light both mediums with continuous light sources (hot lights). Hot lights present their own set of problems for still photography (try photographing a bowl of ice cream under hot lights) but can be used for most applications. There are numerous discussions concerning the cost, benefits and drawbacks of various different brands of lights. Browse around a little bit, or use the search function and you'll find many discussions on the subject.
Jeff Donald
Carpe Diem
Old June 8th, 2004, 10:23 AM   #3
I can tell you from my experience, I prefer to use strobes for photography and hot-lights for video. I shoot 800-1000 pics at a time with my D-100 and the strobes do not heat up the room near as much as hot lights. This can be unfomfortable for the model if a 500 watt bulb is placed 2 feet from their head. Plus, a strobe allows a more relaxed eye. The model doesn't squint as much.
My 2 cents.
Scott Balkum is offline   Reply With Quote
Old June 8th, 2004, 12:49 PM   #4
Thanks for the reply. I guess I can save on the accessories, but for the lights themselves it's better if I get ones dedicated to the functions they were made for.
Thanks.
Old June 19th, 2004, 12:12 PM   #5
If your shooting interviews, portraits, and small commercial stuff kinoflos may work for all the above. Flexible color temps by changing bulbs, dimmable, and best of all, they don't get hot.
Draw backs: the light falls off fast and they are a bit pricey. But if your using for both it may be a cost savings.
Patrick Gault is offline   Reply With Quote
Old June 21st, 2004, 07:41 AM   #6
Thanks, I will check those out.
