A Viable Alternative to Halogen Lamps
Hey ppls, some of you may have reasearched this already, but i think that if someone can adapt these to work on a standard camera battery these will become great lights.
you could use a Ring Array of these LEDs http://www.lumileds.com/products/family.cfm?familyId=4 they come in a ring of 12 LED's and would be great if it could be mounted around the lens, it has an internal diameter of 87.4mm so i'm assuming that lense aren't usually that big around the outside, so it would work quite well seeing as it is very bright, and i mean blindingly bright, and could run off a normal battery lasting alot longer than halogen globes it would be perfect mounted slightly behind the Multi-function ring on the GS400 if it fit that is if you made a ring around the lens it would make that sexy ring in everyones eyes like you sometimes see in music video's and commercials there is also square array of 12 or 18 LED's this would be perfect for a flood light for filming http://www.lumileds.com/products/family.cfm?familyId=5 i'm sure many of you could make a Getto modification to hook up either of these LED array's to use for lighting, it would be perfect for RUN & GUN applications being very light. |
Re: A Viable Alternative to Halogen Lamps
<<<-- Originally posted by Kamal Tailor : Hey ppls, some of you may have reasearched this already, but i think that if someone can adapt these to work on a standard camera battery these will become great lights.-->>>
Have you seen the price of the round ring: LXHL-NW96? It's $198.00. A bit expensive I'd say, for something you can't yet know how much light will output. White LEDs are potentially great for portable lights, but they seem to be a good deal if you assemble them yourself. Then you can determine how much light you will get, for a very reasonable price. Carlos |
Ring lights are not very flattering of most objects including people. They are almost always a tool just for scientific or technical photography.
Still photographers, who could easily use a strobe light that fits around the lens do not. They want a light up above the lens by about 12 to 18 inches if they can. This is because they want some modeling of the subject's features. There are some flat-panel white LED setups available now. A bit expensive but they are nice and are light enough to be held up above a camcorder.
Mike Rehmus Hey, I can see the carrot at the end of the tunnel! |
i built an array after reading about the ones on the dvx forum.
cost me about $30. bright as hell... 50 white 12000 mcd leds. these will cost 2-3 bucks EACH if you go through any normal supplier. but theres a guy on eBay <probably more than one> who sells direct from the factory in china. 50 of 'em for $13... plus $15 for shipping... a couple bucks for a project board alot of time soldering. a battery and charger will cost a bit more i had an 18 volt rechargable drill battery. its chunky, but ill bet it last for hours. i havent done a test to see how long yet, but i dont even have a use for it. i just like projects like this.
Remember, Tuesdays are Soylent Green days! |
