#31 | |
With that range those wireless remotes must be RF then... nice. They looked a little consumer so I was just wondering. |
#32 | |
Nino, dude. Relax. Maybe you've been TOO busy. You need to chill about this. This is NOT the era of absolutes. Nobody's trying to prove you "wrong" and there's NO need for you to try and prove anybody else "wrong." "Quality lighting" is right now and always will be a subjective moving target. I suspect what you lit yesterday was lit to a higher standard than what you lit 5 years ago. I know that's true of my business because I'm always trying to improve and learn. Even at my well advanced age. Just please go back and read your previous posts. In some cases, it sounds like you're taking everybody to task simply because their "tier of concern" doesn't precisely match yours. Well, the reality is that they don't nor should they. Not everybody has your kind of clients. Some people have lower tier - and yes, believe it or not, some people actually have higher tier clients. (For example I'm assuming you weren't called to gaff the new Palm Pre spots that feature 1000 Chinese dudes dancing around a girl in the middle of nowhere. But someone was. And there's no way to know what the heck he or she thinks about color balanced LEDs. Look we ALL have a role to play in this discussion. Your experience and opinions are very valuable here. But so are the opinions of a lot of other folks. Including some who don't have the same level of resources to throw at gear that you and I might. They deserve to be able to drop by and have a discussion of which on-camera LED light works best even if they can't afford to drop a grand on one. Sometimes I'm guilty of the same "my way or the highway" thinking and I'm sure I've even posted stuff here with that tone. And I should be ashamed of it. I forget inside the pressure of my business that the correct spirit here is "how can I help" NOT "how can I prove I know more than this other guy." Oh, and just for the record, my Cool Lights were ordered with the accessory mount bars that let you group them in clusters of 2, 4, 6 or whatever, just like the litepanels so that 4 light stacked panel LED array would run you under 2 grand or just twice what your 1K with diffusion would run. And you could mount it on a single baby roller stand which because of the light weight of the instruments wouldn't even need sandbags. With an Anton Bauer on the back of each, you'd save yourself and your crew the TIME to find power, run a stinger, set up the frame and stands and sandbags for the silk and have to break down and re-set all that stuff on every move rather than just rolling the light over, hitting the ON switch and moving on to start thinking about something else. Yes, that light array may or may NOT be to your standards when you try it out. But you don't know that until you check the new stuff out for yourself - as I'm SURE you will before long. I know I'll be right there with everyone else, very curious and even anxious to hear what you think about LED panels when you've actually have a chance to use them. Until then, you're guessing just like we all were before we bought a few and started learning their unique attributes. So please, dial down the skepticism just a tad. You're scarring the young folk. And if you find yourself out here near Scottsdale, give me a call. A case of cold Tecate', some limes and a couple hours by the pool and I bet you'd start feeling a WHOLE lot better. Peace. |
#33 |
I saw the new Lowel small LED light this evening. It is very well made. It has large LEDs in both cool and warm. There are two dimmers, one for each color temparature. The dimmers operate in steps, so they can be set quickly to a known setting. The dimmers change the brightness at each step, so it seems they are calibrated somewhat to match the LEDs.
Different camera battery sleds will be available (Panasonic, Sony, etc.) with a wire and a plug into the light to power it. I think the kit also has an AC adapter. Unlike the PrompterPeople light, you don't have to choose what battery you will use. There are too slots for filters. I don't know what may be supplied with the kit. I can see many uses for this little light. And it seems more practical for my uses than the Zyights. I won't comment on the quality of the light. It is supposed to be out in the fall, I think. A possible MSRP is around $650. But that's not set yet. This looks like it could be used on camera, on a stand, as a backlight, as fill, as a colored spot in the background, to lighten up shadows, etc. It has some nice features that take it a step beyond the basic small LEDs. |
#34 | |
It's great to get a hands on review from someone who has actually tested it against several style lights, especially head to head against the Sony HVL light. I might try to sell off my Sony lights and replace them with Comer's or wait until the Lowel Blender light comes out and give that one a try. But of course the Blender light is going to be double the price of the Comer. |
#35 |
Well curiosity got the best of me today.
I went ahead and ordered a Comer 1800, and am going to compare it against my HVL light. But most likely I will find out the same as what was already mentioned here. That it's stronger than the HVL light, and for me even most importantly I can use non-Sony batteries with it. Which is a huge plus in my book. I am also going to like the fact that the diffuser is already gelled to be 3200k. I normally have been attaching a 3200k gel to my barn doors on my HVL light. I am curious about one thing though. It seems that the glass on the front of the light already has a diffusing grid applied to it, which the Sony HVL does not. If this is the case, then it makes the light even better as I wouldn't have to apply the color gelled diffuser at time for even more light. Although I like the tip that Barry mentioned of applying both the spot throw and diffuser doors to get an indoor balanced flood light at a bout the same output as non-diffused. I'm amazed that I never thought about trying this with the Sony light all of these years. =( |
#36 |
I am using the light now on my vacation in Maui - very pleased with it - much more powerful than the Sony - when using indoors with mixture of daylight and tungsten I set my white balance at 4500K and the skin tones look good. It is also useful for fill outdoors - Sony was never powerful enough to do this - I just set my white balance for 5200K in the stong daylight situation and the skin tones are fine.
#37 |
I'm using a 50W halogen with a dimmer for regional tv shootings because I often need this much output when there is no time and manpower to set up lights (and there almost never is!)
Usually I put a big piece of 216 in front to make a little "softbox" which gives me a nice and even light, I also have a 1/4, 1/2 ctb with me, plus the included 3/4 ctb glass filter. I used it with 1/2ctb plus half WD recently on a shoot where a national station had a couple hmis running - it was still powerful enough. On occasions where it's really dark I can switch the lamp to a 20W so I won't overpower everything, and I don't have to dim down the 50W to below 50% I don't see any LED light that can do this for me, and I really don't get people's enthusiasm about on-camera LED lights... I'm not sure to which Sony light you are comparing the LED, Barry, but if it's the double-headed Sony thingy that I know, then of course ANYTHING would be better than that. I had to use that thing once, the light was spotted too much and still hardly powerful enough to give me exposure a few feet from the camera... |
#38 |
Barry is comparing the light to the Sony HVL-LBPA light. Sony | HVL-LBPA LED Light System | HVL-LBPA | B&H Photo Video
It's a much larger but better light then the Sony 10/20that you mentioned. It gives a nice broad even spread of light when used normally. The light output from the HVL light is one of the stronger ones out there. And the new Comer light seems to trump this as well. While I still love using my NRG Varalux light, I only use it for off camera lighting now, as I hate being tethered by batteries and cables. This is one of the major draws of LED lights, in that many of them can run on internal rechargeable or self mounted batteries. And since they draw much less power than standard lighting, you can run them for longer periods. |
#39 |
Another good thing for the Comer lights (other than the 1800lux Comer output compared to 1200lux Sony output), it takes third party batteries. Sony lights only work with Sony batteries. That's a rip off.
The light can also be mounted on tripod to be used off the camera. It's a good investment I would say. I am selling it but I am also using them wedding events. It is very useful and powerful. Not just regular on-camera light that casts a soft circle to the scene.
LA Color Pros Blog RODE Authorized Reseller . Comer LED Camera Lights . TakyBox HTML5 Menu Generator |
#40 |
Just got the Comer 1800 today, and like what's been said it seems almost identical to the Sony HVL light. With the only visible difference being the power and dimmer are combined on one knob instead of a separate dimmer knob and power switch.
Also the lens itself seems to have a diffusion grid etched into it, which the Sony HVL is straight glass or plastic. I just received it in work, so I don;t have any batteries to test it with. But I plan to try both Sony and non-Sony batteries. Looking forward to seeing how much brighter this light is. |
#41 |
Michael, I also have generic brand NP-F970 battery and charger to be used with the light
NP-F970 Battery and Charger Do you also own the Sony HVL light? If so, it would be nice you can share your experience the difference between these 2 lights. Thanks
#42 |
Ok, just compared the output between the Sony HVL and Comer 1800 light, and it wasn't even close.
The Comer light was far brighter than the Sony HVL light. Even with the 3200k diffuser lowered on the Comer 1800, it was till brighter than the SOny with no diffusion applied. I took Barry's suggestion and applied both the diffuser and spot focus filter and gpt a real strong 3200k flood light. All in all real nice throw. Last edited by Michael Liebergot; June 16th, 2009 at 07:01 AM. |
#43 | |
#44 | |
Especially since the Sony HVL light was considered one of the stronger ones out there. The only thing that I have to figure out is how to mount it higher up and off axis on my camera, as the light is BLINDING when you are looking directly into it. Not much more blinding the the Sony light, but it is more intense. I might be able to mount the light on a light stand like I do with my other off camera lights that I power with battery belts. I was never able to mount the Sony light on a stand, as there wasn't a way that I could wire the light to take the remote control that I use to power the off camera lights on and off with. Since the Comer light has the ability to take a power tap, I mihgt be able to do this now. I'll have to test and see. |
#45 |
Michael, glad you like the comer light. At the bottom of the light mount, there is a thread hole you can mount the light on any camera tripod too. Or you can get some mounting accessories
Tripod Mount and Desktop stand
