Lamp sockets needed at DVinfo.net
Photon Management
Old February 24th, 2004, 10:15 PM   #1
Lamp sockets needed
Anyone know of a distributor or retail outlet for those ceramic lamp sockets that are used by the MR16 halogen lamps? These are the little halogen bulbs with the built-in reflector. Similar to a bulb in a slide projector.
I need about 10 of them.
Mike Rehmus
Old February 24th, 2004, 10:17 PM   #2
Never mind, I found them. Simple search turned up dozens of suppliers this time. Not cheap though.
Mike Rehmus
Old March 5th, 2004, 09:04 PM   #3
Chimera Lighting
I am processing your request and.......
I would try bulbtronics.com....
r
Strength and Honor
RLV
Richard Veil is offline   Reply With Quote
Old March 6th, 2004, 02:34 PM   #4
Mike, you might take a look at Ushio's line voltage lamps that are similar to the MR 16s but use a standard base. Go to this link and look at the bottom of the page. I think you can save some $
http://www.ushio.com/MR_16s.htm
Wayne
Wayne Orr is offline   Reply With Quote
Old March 6th, 2004, 02:47 PM   #5
These are a very nice alternative that we use in the theatre frequently. Specifically, we have a bunch of miniature "par cans" that use the line voltage candelabra base MR-16's. These units are often called "birdies" and are handy for concealing inside scenery or other tight spots onstage.
Old March 6th, 2004, 07:36 PM   #6
Thank you. Too bad the screw-in lamps are 75 & 100 watts at wall-socket voltage but they are nice to know about.
Mike Rehmus
