Paglight C6 Kit / Where to buy accessories? at DVinfo.net
Photon Management
Old December 20th, 2003, 04:31 AM   #1
Hello. Just purchased the Paglight C6 kit from a DVINFO sponsor, Express Video Supply. But I am unable to find where to purchase accessories such as an additional battery pack and lamp holders/dimmer. Anybody have luck w/ finding these for sale online?
Thanks.
Paul
Paul Nuttall is offline   Reply With Quote
Old December 20th, 2003, 03:03 PM   #2
I have that light.
As far as I know, there is no dimmer available for it. The Pag dimmer you may see advertised is for their
larger lights. The only lights that work in it are a
10W, 20W, and 30W. The lamps for the larger Pags
do not work in it -- too big.
Extra battery could probably be ordered from Pag USA.
Dave Largent is offline   Reply With Quote
Old December 23rd, 2003, 12:25 PM   #3
Hi Dave. Just curious, what are you using your kit for (application)? And, have you purchased bulbs, if so where? Thanks.
Old December 23rd, 2003, 01:35 PM   #4
Paul,
On a four hour charge, the light runs two hours with the 20W lamp. On a two hour charge, it runs one hour.
Half hour charge will get you 15 minutes. And so on.
I use it as a gentle fill light. Mostly for wedding receptions.
With the right setup, *nothing* beats it. Also used as an outdoor fill to open up dark shadows.
Lamps can be purchased direct from PagUSA for ~$10.
Old December 23rd, 2003, 01:48 PM   #5
What do you consider to be the "right" setup? For weddings do you find the supplied diffuser to be enough?
