Blue gels absorb so much. at DVinfo.net
Photon Management
Old April 8th, 2009, 05:57 AM   #1
I was wondering how often people use blue gels for colour correction as I often find them to be a pain? I thought it was the quickest and easiest option but the full ctb and diffuser absorbs so much of my lights power (Tota light) that I'm stuck with the bare minimum iris setting. I think I might go with covering the windows with cto instead, despite the extra time.
Leslie Knox is offline   Reply With Quote
Old April 8th, 2009, 07:57 AM   #2
It's not that common for people to gell the windows for colour correction and large windows can be a problem. One advantage about the UK power supply is that you can plug a 2k straight into the wall, which works pretty well with a CTO and diffusion - it's about the same output as a 575 watt HMI. Although it can get warm under the lights.
I suspect part of your problem may that you're shooting HDV and those 1/3 cameras aren't the most sensitive. The 800 watt CTB & diffusion combo is fine with the more sensitive SD cameras or 2/3" HD cameras..
Old April 8th, 2009, 08:24 AM   #3
Brian,
Yes, I'm using the Z1 which is a real pain in low light. As you say with a better/different camera I'm sure it would be less of an issue. I'm going to play around with a half ctb and see if that helps.
Old April 8th, 2009, 08:35 AM   #4
Leslie: I routinely use 1/2 CTB if I can get away with it. Transmission factor is somewhere in the neighbourhood of 50% (it changes across the light spectrum) versus about 25% for the full blue, based on my Roscolux swatch book. SOME variation in colour temp in a scene is ok by today's standards, depending on the nature of the work and if you are mixing in overhead "daylight" fluorescents, the half blue is closer anyway (just watch out for green spikes if the fluoros are older...)
Old April 8th, 2009, 08:38 AM   #5
As well, my experience with the Z1 leads me to believe that +3 to +6dB of video gain isn't THAT noticeable, depending on the application. Or a 3 way colour corrector in post allows you to claim back SOME exposure through careful use of the highlight and gamma controls, if you're still a little dark after lighting with correction, ASSUMING you are doing your own post.
Old April 14th, 2009, 07:10 AM   #6
Warm balance your camera.
Brian Berg is offline   Reply With Quote
Old April 14th, 2009, 09:08 AM   #7
Contributor
I prefer to gel the windows when possible, but if they're too big or there's not enough time, I'll gel the lights. Often I'll use 1/2 CTB instead of full and white balance for that, then let the background go just a bit more blue. I found the Z1 to need about 1/2 - 2/3 stop more light than a DSR250 under the same circumstances.
Old April 14th, 2009, 05:06 PM   #8
"Blue gels absorb so much."
If you look at the spectral qualities of a tungsten light, and compare it to daylight, you'll see the tungsten light most of its energy in the red end of the spectrum. Whereas daylight has much more in the blue end of the spectrum.
Filters work by absorbing energy. A red filter absorbs blue. A blue filter absorbs red. A neutral density filter absorbs everything equally.
To get the spectral distribution of the tungsten light to be a closer match to daylight, a filter has to subtract out red. And unfortunately that's where most of the tungsten light emits most of its energy.
So the end result is that the gel absorbs most of what the tungsten light emits to emit a light with spectral qualities roughly similar to daylight.
That's why I'm starting to buy daylight-balanced lights. It's easier to filter a light to match tungsten, when the situation probably needs less lumens, than try to get a reddish light to match daylight, when you need all the output you can get.
Technical correction: Red filters out cyan. Blue filters out yellow.
Dean Sensui
Old April 14th, 2009, 06:20 PM   #9
Just pick the color opposite to the color on the color wheel that you want to filter for.
4096 Color Wheel Version 2.1
http://www.coollights.biz
Richard Andrewski is offline   Reply
