Lens Shade Flare helper at DVinfo.net
Photon Management
Old November 21st, 2008, 11:43 AM   #1
I saw this here once, but can't seem to find it anymore. Its a double-clip that attaches to the lens hood, and holds a flag. Sort of a cheap DIY French-Flag kit (minus the flag). The clips are black "bulldog" style clips attached with a short wire armature. Any help would be appreciated.
Oren Arieli is offline   Reply With Quote
Old November 21st, 2008, 12:15 PM   #2
I just use CineFoil, works like a charm.
I have seen FF clips/arms at FilmTools and Mole Town where there is a clip on either end with a flex arm, but no flag, you just use Cinefoil, Coreplast or show card.
Dan
Old November 21st, 2008, 05:39 PM   #3
I'm hoping for something more elegant than cinefoil. I have it, but it looks ghetto. I'd rather not add the weight of a full matte box, so a flag&clip would be perfect (and can be removed quickly for stowage.
Old November 21st, 2008, 06:45 PM   #4
Contributor
You can get a clamp-on French flag pretty cheaply:
http://search.store.yahoo.net/cgi-bi...&go.x=0&go.y=0
Or if you want a very lightweight simple mattebox to hold 2 filters but without the rails, Lee Filters has the wide angle lens hood with 2 filter slots:
http://www.bhphotovideo.com/c/produc...Hood_Wide.html
In addition you need the threaded adapter. I have one and it weighs just under half a pound. It's wide enough so even with the bellows extended all the way you don't get any corner vignetting. I also have a clamp-on French flag but haven't needed it since I got the Lee. Here's an article about it with pix: http://dvfreelancer.com/articles/gen...eLensHood.html
I used a French flag for years and only got the matte box when I got an XH A1 and needed to start buying new filters. There are some French flags that have a hole 1/4" screw with wing nut, if you have a camera with the 1/4" receptacle on top of the camera.
Old November 21st, 2008, 07:31 PM   #5
Hi Oren,
That "clip" is a common business type, and usually found in any Business Supply store in many sizes.
Dan & Bill,
I've made up one of those flexabile flag holders using a clamp (as in Oren's pic) to hold the flag, a flexable magnet tool (sans the magnet), and either a Hot Shoe attachment or another clamp type - for Cam or T-Pod attachment.
You can also attach a flag to your Hood using a Velcro strip.
You can also just make a longer Lens Hood.
Just some ideas that I've done, and used. Cheap & easy to do.
Harold
Harold Schreiber is offline   Reply With Quote
Old November 21st, 2008, 10:47 PM   #6
Are these the ones?
NinoMedia Productions - EFPLighting.com Advanced Lighting and Gripping Workshops
Nino Giannotti is offline   Reply With Quote
Old November 22nd, 2008, 01:15 AM   #7
Nino you're the man of the hour! That's exactly what I was thinking of....now for the $20 question, where do you purchase them (and what is their proper name). Thanks a bunch to all who responded.
Old November 22nd, 2008, 12:29 PM   #8
I'll try to find out who makes them, I was sure it was Bogen but I can't find them on their web site. Maybe they are discontinued. I'm sure I still have some new ones I have to dig them out. I'll let you know.
Old November 22nd, 2008, 02:13 PM   #9
Contributor
Here's something similar:
http://www.bhphotovideo.com/c/produc...Multiclip.html
Bill Pryor is offline   Reply
