Lowell Omni Lights Replacement Bulbs at DVinfo.net
Photon Management
Old November 3rd, 2008, 10:34 AM   #1
Just in case anyone has any Lowell Omni lights and is looking for replacement bulbs,
I ordered replacement bulbs (FTK 120V 500W) from B&H and they did not fit into my Omni light. I called B&H and they tested the bulb with the light, and sure enough it did not fit either. (Props to B&H for actually going and testing it while I was on the phone)
I was then informed by B&H that the bulbs I had ordered were listed as the correct model and size, but B&H was shipped the wrong bulb from the manufacturer! So make sure you find out if they have received new bulbs in before ordering these bulbs.
Ryan Postel is offline   Reply With Quote
Old November 4th, 2008, 10:15 PM   #2
We had a similar issue with another retailer a couple of years ago with the replacements for the Pro light. The replacements had a cast "nipple" on the end of the lamp that kept it from fitting behind the safety glass. Thanks for sharing!
