LED Lighting Update
Found this article about improvements in LED technology.
I may hold off on buying LEDs for now. Toshiba Creates Better White LEDs With New Breakthrough : TreeHugger Kevin Jones |
That's a substantial improvement. At least 2 to 3 stops better!
Dean Sensui Exec Producer, Hawaii Goes Fishing |
#3 | |
Looks good but I read something about UV and that got me scared!
And it won't be out for another year at least nor do we know anything about price or suitability as a video light.
If you're not ready for a LED lighting system, just don't buy one now. Waiting for stuff that may be "just around the corner" really makes little sense if you need to get on with business. George/ |
#5 |
Don't worry about LED UV output - not the same type as harmful UV-B. LEDs emit UV-A, the longest wavelength that is just above the top limit of our ability to 'see'. It's the kind of UV that makes things fluoresce. The UV LEDS are being used in place of the older fashioned discharge UV sources and UV fluorescent tubes. So far, they're not 'quite' right, being a little too visible.
Over the past year, I've seen LED fixtures starting t get quite bright, and less yukky on white. They're not there yet, but with a bit of messing with colour balance are just about ok. I won't be buying any yet, but probably soon! |
#6 |
Contributor
The white seems fine on mine: http://www.prompterpeople.com/led500.php
And Litepanels are good too, even more compact and lighter weight; also Kino Flo has a new one. |
#7 | |
Lupine Lighting Systems - Lightsets - Betty 7 |
