Good dimmable light for XH A1? - Page 2 at DVinfo.net
Photon Management
Old April 14th, 2008, 05:24 PM   #16
Originally Posted by Suzanne Zorich View Post
Nice, though it's a few hundred more than the Frezzi's listed...is there a suitable recommendation from the links I provided above?
Suzanne, forget the 30v versions... just go with a 12 volt one. They come in different configurations (depending on how you intend to power them). It doesn't matter which wattage bulb either, because you need to rip that thing out of there & throw in that Sylvania one I mentioned earlier :)
Mine has the 4pin XLR cable. I'm probably one of the remaining few that still wears power belts. A co-worker has the same Frezzi but uses a NP1 pouch (not sure of the manufacturer) that's terminated with a short 4pin female xlr. Just plug the frezzi's cable into it. They run a 50w light for nearly all day with the NP-L7S batteries from IDX. Someday I'm going to retire my belt :)
Old April 15th, 2008, 05:34 PM   #17
Do you guys any cheap on camera light under 200? thx
Kiflom Bahta is offline   Reply
