Scrim? at DVinfo.net
Photon Management
Old February 18th, 2008, 02:00 PM   #1
Scrim?
What is a scrim?
Andrew Mesin is offline   Reply With Quote
Old February 18th, 2008, 02:08 PM   #2
Originally Posted by Andrew Mesin View Post
What is a scrim?
It's a wire mesh that can be mounted onto a light (usually behind the barndoors) to reduce light output. They come in various grades and also as a half, which covers only half the light, so you get full output in one half of the beam and a reduced light level in the other half.
Old February 18th, 2008, 02:43 PM   #3
so if it just reduces the output, what is the difference between a scrim and regular diffusion?
Old February 18th, 2008, 02:53 PM   #4
It doesn't diffuse, it leaves the light hard. You have the full focusing and barn-door cutting capabilities the light originally had.
The scrims are made of wire mesh, therefore they can be very close or touching the lens and they will never catch fire. They're also very quick to work with, but be sure to bring your gloves because they can get hot.
Generally, a professional rig of a fresnel will include full, double, half-full and half-double scrims, greatly increasing the versatility of the light. And you can still use diffusion if you want it.
Old February 18th, 2008, 03:39 PM   #5
And most of all, don't forget a scrim bag, they are very handy for hanging the scrims off of the light stand so that they are handy and right there for you to use.
Dan
Old February 19th, 2008, 10:08 PM   #6
Would a DIY approach using window screens work, assuming they aren't the cheap-o plastic type?
Lloyd Claycomb is offline   Reply With Quote
Old February 19th, 2008, 10:21 PM   #7
You may also want to have a two doubles.
When the fixture has no scrims-"steel", it's "clean".
Drop some steel- Add a scrim, sometimes you'll have an idea of what to use. If not, ask the Gaffer.
When you drop the scrim in, say what it is you are putting in, example:"Single in."
Double - Double scrim
Triple - Single + Double
Home Run - 2 Doubles
Grand Slam - 2 Doubles, 1 Single
DIY, not so much. You can get skewered by the loose wires sticking out. Not safe. The single cuts exposure bout half a stop. Double about a full stop. They have a color coded ring to prevent the wires from unraveling and pricking you. Single us green, double is red. Some manufacturers have alternating color and no color for the halves.
Mark Sasahara
Director of Photography
Mark Sasahara is offline   Reply With Quote
Old February 19th, 2008, 11:32 PM   #8
Thanks a lot for all the help guys.
Old February 20th, 2008, 06:54 AM   #9
So if it reduces exposure by half stops and stops, but yet doesnt diffuse, whats the difference between scrims and ND gels, other than durability?
Ollie Bartlett is offline   Reply With Quote
Old February 20th, 2008, 10:42 AM   #10
The differences between the two are resistance to heat/melting and ease of use. With ND gels, they have to be clipped to the barndoors (which limits the doors' ease of use) or flown on a frame (sometimes requiring another stand). A scrim just pops into the light in no time, that's it. So, you're controlling the light without really adding anything. When all is said and done with scrims, you've got a light of the same dimensions and maneuverability as before with no noisy gels hanging off of the doors.
Hope that helped.
~~Dave
Dave Dodds is offline   Reply With Quote
Old February 20th, 2008, 07:04 PM   #11
The window screen material on all of the windows on my house would go up in flames in about :30 in front of a 1k. I don't think most of them use actual wire mesh anymore, it's coated and sort of Nylon looking in most cases.
Why make scrims? They are one of the cheaper parts of lighting gear and do a really great job.
Dan
Dan Brockett is offline   Reply
