Color Temp. Thermometer? at DVinfo.net
Photon Management
Old February 14th, 2008, 07:07 PM   #1
Don't laugh, but is there such a thing? I know it wouldn't be a "thermometer;" just a play on words... But is there some device that can tell you what color temp is at a certain location?
Lloyd Claycomb is offline   Reply With Quote
Old February 14th, 2008, 07:08 PM   #2
I think they're called light temperature meters or something along those lines - they exist. Check B&H? I know they'd have em.
Carl Middleton
Whizkid Mediaworks
Carl Middleton is offline   Reply With Quote
Old February 14th, 2008, 08:00 PM   #3
Here are a couple color temperature meters:
http://www.bhphotovideo.com/bnh/cont...arch&Q=*&bhs=t
Old February 15th, 2008, 08:34 PM   #4
Yes, the color temperature meters are pretty expensive but occasionally you can pick a used one up on Ebay. The Gossen ones are the most commonly found ones.
http://www.coollights.biz
Richard Andrewski is offline   Reply With Quote
Old March 3rd, 2008, 04:45 PM   #5
If you've got a digital still camera, you can read the Exif or RAW data. This is a good cheap option if it's only for occasional use. Set you camera for Auto White Balance or No White Balance.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old March 3rd, 2008, 08:05 PM   #6
Contributor
I have a Gossen color temperature meter and have had it for many years. Not too expensive and works great. I never used it when shooting with 2/3" chip cameras because they give you the color temperature readout. I don't have a clue why they won't put that feature on smaller cameras--the damn things know what the color temperature is when you white balance and it would be no problem technically, I think, to simply display it in the viewfinder. They give you a readout for every other possible thing you might want to know--why not degrees K???
Old March 4th, 2008, 04:53 PM   #7
Is this he Gossen analog meter?
Jack Walker is offline   Reply
