Question about softbox for V-Light
Anyone know of a softbox that can be used on a Lowel V-light? Preferably under $150.
For almost no cost, you can use an umbrella with a V-Light or bounce it off a piece of foam core.
Chimera makes a speed ring for the V-Light: http://www.bhphotovideo.com/c/produc...for_Video.html But then you need a soft box to go with it: http://www.bhphotovideo.com/c/produc...s_Shallow.html This comes to close to $250. I think it would be better to use the V-Light with an umbrella (or bounce off of foam core.). Unless the softbox has grids, the umbrella will give you a similar result, at almost no cost. Also, the speed rings and soft boxes on broad lights are a small project to set up. I have a speed ring and a Photoflex box (long and narrow) I use with a Tota light. It works well, but it is time consuming to get put together. I have a couple of Rifa lights that setup up in a minute. For a straight soft box I really like these and believe they are worth paying for. Put the $250 toward something like the Lowel Rifa 55: http://www.bhphotovideo.com/c/produc...box_Light.html Which is 500 watts and about $450. Or even the Lowel Rifa EX 44 (250 watts) for $313: http://www.bhphotovideo.com/c/produc...W_Softbox.html But perhaps there is a less expensive soft box option for the V-light that I don't know about. Last edited by Jack Walker; February 13th, 2008 at 03:10 AM. |
Thanks for the advice!
you can also use the photoflex speed ring for the tota with the v-light. the speed ring and a small photoflex silverdome will run you about $200 at b&h, $250 with the medium silverdome. umbrellas are good in a pinch, but the spill can be tough to handle when you need controlled lighting.
