Greenscreen?
Looking to set up a small, 8x10 greenscreen for some shot in a small room, say 15x18' would a standard greenscreen backdrop like a muslin like this one http://www.bhphotovideo.com/c/produc...ackground.html be good or is there better without going to an extreme of expensive backgrounds, and would you think two softboxes at the screen and two rims at the actor would be best, should I use a minus green gel on the rims or 1/2 magenta? to counter any green spill?
Would it be helpful at all to use minus green on the mains and rims and WB for that with no filters on the background so the green becomes even more green in relation? Mains would likely be a soft broad light from two lightbanks of about 4x6 foot size. |
Although not specific to your question, there's a lot of good info on this thread I started. I had/have similar questions: http://www.dvinfo.net/conf/showthread.php?t=113884
#4 | |
So, I'd suggest that you keep white light on your fill and key and have nice color rendition and skintones on your subject. The screen material is fine for most use, and keys are generally easier to cut if there are no visible shadows from wrinkles in the fabric. Many times this is acheived by stretching it between stands, or on a frame, etc. |
#5 |
virtually all modern keyers handle spill suppression very well. its not as much a problem as you think. just keep people 5+ feet away and everything should be good. I try to keep them 10ft away for waist up shots.
#6 |
Always white balance to the subject lighting but the rim lighting should not be part of the white balance. Turn off the screen and rim lighting and just white balance to the foreground subject lighting.
The idea behind using a magenta (minus green) gel for rim lighting (and a amber for blue screen) is that you pick the color opposite of the screen color to counteract it. As someone else pointed out though, with today's modern screen compositing software, most of the spill suppression takes care of any spill pretty well as long as the separation between subject and screen is good enough to keep it to a minimum. |
