electrical book recommendations needed at DVinfo.net
Photon Management
Old June 9th, 2003, 07:47 AM   #1
I've been doing lots of reading on lighting lately, but one of the things I keep running into is that, even though I know all the formulas about making sure I don't blow circuits, I'm still pretty ignorant about the fundamentals of electricity. For example, I really couldn't tell you the difference between amps, volts, and watts.
So, can anyone recommend a book on electricity that doesn't read like a technical text but also isn't focused on home improvement? (Right now I'm wishing Larry Gonick would write "The Cartoon Guide to Electricity").
Stu Minnis is offline   Reply With Quote
Old June 9th, 2003, 10:20 AM   #2
I bought this book right here...
http://www.amazon.com/exec/obidos/tg...qid=1055175713
Lighting for Digital Video & Television
There is a big chapter in there all about watts, amps, volts and all the technical electrical jargon. It's very easy to understand. A simple way to think about it is that the flow of electricity is like the flow of water in a pipe. Voltage can be thought of as the speed the water is traveling, and Amps can be thought of as the amount of water that's traveling at that speed.
Volts x Amps = Watts
Amps = Watts/Volts
moderator edit: removed Amazon's user ID from the URL
so that everyone looking at the book isn't being logged as "Brad"
Brad Simmons is offline   Reply With Quote
Old June 9th, 2003, 08:52 PM   #3
A good understanding of ohm's law will get you through anything electrical. If you don't understand ohm's law you don't understand electricity , period!
http://webhome.idirect.com/~jadams/electronics/ohm.htm
Bryan Beasleigh is offline   Reply With Quote
Old June 9th, 2003, 10:16 PM   #4
I f you really want to know about lighting, you kinda have to read this book:
Set Lighting Technician's Handbook
Film Lighting Equipment, Practice, and Electrical Distribution
by Harry Box
Other books on lighting:
http://www.bhusa.com/focalbooks/us/s...eld=&operator=
Stelios G.M.
Stylianos Moschapidakis is offline   Reply With Quote
Old June 11th, 2003, 04:56 AM   #5
RED Code Chef
Sounds interesting!
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
