must have in every gaffers bag...? less than $100 at DVinfo.net
Photon Management
Old September 4th, 2007, 01:49 AM   #1
Gaffer tape
Clothes pin c-47
gel filters
stingers
velcro cable ties
Manfrotto super clamp (which is better quick action clamp or super clamp?)
collapsible reflectors
what else?
Juan Dela Cruz is offline   Reply With Quote
Old September 4th, 2007, 02:55 PM   #2
Pony clamps 6" and 4"
Electrical Tape
I keep a dozen 6" bungee balls with me
Gloves
Small and large door stops
Cinematographers Bring Shadow To Light
Bill Hamell is offline   Reply With Quote
Old September 4th, 2007, 03:07 PM   #3
I like to keep a sandbag or two. I use the 'fillable' kind, so I can fill them with sand/shot/whatever if necessary, and don't have to haul the weight if I don't need it.
Richard Alvarez is offline   Reply With Quote
Old September 4th, 2007, 11:57 PM   #4
plugin outlet checker, $10.
can potentially save your life when you encounter a live ground when plugging into unknown wall power. found a live ground in a marina shore power outlet that I was gonna power a light from hung on a metal pipe support for a awning. could of electrified the entire structure.
some 1/4-20, 3/8, 5/16, 1/2" nuts and bolts. cost is a couple of dollars and can save your you know what when you need it
skip the manfrotto maffer clam, at least the cheap black ones. they break ! the castings are filled with air and can let go at anytime if you use them to hang lights or heavy items - say 10 lbs +. get the more expensive "gravity" cast silver ones instead. you get what you pay for.
couple of 5/8" pins, maybe 4" long. use them for mounting lights in c stand arms, grip heads, ect.
digital volt meter with freq counter
clamp on amp meter
Steve Oakley is offline   Reply With Quote
Old September 5th, 2007, 02:54 AM   #5
- Blackwrap
- Converter from E27 lightbulb socket to power socket.
- Dimmers
Heiko Saele is offline   Reply With Quote
Old September 5th, 2007, 08:16 PM   #6
Gotta' have some tin foil...
Benjamin Richardson is offline   Reply With Quote
Old September 5th, 2007, 09:22 PM   #7
DVi Contributor
well, how about a good used Sekonic light meter. You can pickup a studio deluxe for less than 100 bucks.
Craig Chartier is offline   Reply With Quote
Old September 6th, 2007, 10:17 PM   #8
Keys to the padlock on the back of the 5-ton
David Garvin is offline   Reply With Quote
Old September 7th, 2007, 05:33 AM   #9
Steve,
Why with a freq counter? How/why would I use that feature?
Thank you,
Bill
Old September 7th, 2007, 11:51 AM   #10
20' extension cord
Leatherman multi-tool
small maglite
youtube.com/benhillmedia
linkedin.com/in/benhillmedia
Benjamin Hill is offline   Reply With Quote
Old September 7th, 2007, 02:39 PM   #11
DVCreators.Net
Here's a pretty good article to check out http://www.dv.com/features/features_...cleId=18901484
Although, I'm diggin' the Harbor Freight dimmers these days.
http://www.harborfreight.com/cpi/cta...emnumber=43060
Guy Cochran
Old September 7th, 2007, 11:09 PM   #12
I've learned to always pack a small flashlight...
Bill Zens is offline   Reply With Quote
Old September 11th, 2007, 11:05 PM   #13
Originally Posted by Bill Hamell View Post
Steve,
Thank you,
Bill
to check line freq, especially with small / cheap generators. yes I have a meter thats happy to read 120V in freq mode. ideally you find one that can resolve to .1hz
they can also be handy when in forgein countries, especially tourists hotels where you can find a suprising array of different power types, like 120V 50 or 60hz in a hotel that caters to NA customers, while another caters to Euro customers has 220V 50hz. depends on if they get power from the grid or local generator.
Old September 20th, 2007, 05:31 PM   #14
Thank you Steve.
Oh boy! A new tool to reserach and buy!! :-)
Bill
