Playback monitor? at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > Photo for HD Video (D-SLR and others)
HD from Nikon D90, other still photo cams (except EOS 5D Mk. II, LUMIX GH1).
Old May 7th, 2011, 08:31 AM   #1
Playback monitor?
I see on professional sets that a director watches the scene through a playback monitor. is there any equivalent that DSLR videographers could use? I was thinking of using an older HDTV i have would that work?
Lee Tamer is offline   Reply With Quote
Old May 8th, 2011, 07:35 PM   #2
Re: Playback monitor?
A number of newer production monitor s have HDMI inputs so all you need is the proper cabling (usually HDMI Mini - HDMI) to connect the monitor. You can use a HDTV but it will not be as accurate for framing and color. Also, if the monitor has a DVI input you can use a HDMI to DVI cable or adapter. DVI is basically the video portion of the signal coming from and HDMI.
-Garrett
Garrett Low
www.GLowMediaProductions.com
Old May 9th, 2011, 02:13 PM   #3
I never knew the industry term was production monitor. Thankyou for the advice
  You are here: DV Info Net > High Definition Video Acquisition > Photo for HD Video (D-SLR and others)
