Casio EX-F1 720p30 video- impressive! - Page 7 at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > Photo for HD Video (D-SLR and others)
HD from Nikon D90, other still photo cams (except EOS 5D Mk. II, LUMIX GH1).
Old February 22nd, 2009, 08:38 AM   #91
HDV Cinema
Originally Posted by Ralph Smith View Post
Hi Jay
I was browsing around and saw your comment on having both the F1 and the D90. I've been using the F1 quite a bit and trying to get the hi-speed down for weapon testing at 300-600 fps (had the fh20 but video was too small). Is there any definitive info in one place on using the F1? Also what is the prefered editing program, as the video is making some viewers dizzy even when played back in the camera. I have a D90 but havn't used it since I picked up the F1, I can return the D90 to Costco in the next 60 days. What are your thoughts on the F1 compared to the D90 for video? I have a HVX200 but am in the process of learning how to use it.
There is about ZERO info on the F1. I'm still exploring it.
I really like iMovie 09 because I can edit it natively (no conversion to something else) in REAL-TIME.
If there were tons more buyers I'd do a book. But, we are a tiny minority cause everyone thinks the Nikon simply must be better. It ain't, as we know, but Nikon sells anyway.
Old February 25th, 2009, 07:00 PM   #92
I have the F1 and use Vegas9 platinum for editing, everything besides the 1080i mode (doesn't look better than 720P but grinds my computer to a halt.).
No conversion, and in real-time as far as I can tell.
Works like a charm and is very user friendly for me as a beginner.
Se my testmovie at vimeo:
Slomo test in the snow and a bird in the end on Vimeo
I love my F1, just waiting for some decent weather. The F1 was the only option for me, I used to have two analogue cameras, one Nikon F65 and a 8mm camcorder and the problems was that I usually took the wrong equipment with me. It's a decent still-image camera and an amazing camcorder if used properly. Thanks again Steve for all you hard work investigating this camera!
Hans Brauer is offline   Reply With Quote
Old March 4th, 2009, 01:30 AM   #93
I just ordered the Casio ex-f1, and I probably will get the SteadyTracker UltraLite with it. Is it an ok combination? Will do some wedding shooting with them (not the whole wedding, just some footage). SteadyTracker is cheap and really lightweight, and probably will do the trick.
One other thing. I was considering of getting the Raynox HD-7062PRO (Raynox HD-7062PRO, HD-7000PRO 0.7X High-Quality Wideangle Conversion Lens for Digital Video Camcorder). It is an 0,7x wide-angle converter. It should fit the ex-f1 straight with the 62mm threads. Have I understood correctly, that when shooting 720p the ex-f1 has an agle of view of approx. 45mm? And when shooting 300fps it is 36mm? Therefore those numbers would be 31,5mm (720p) and 25,2mm (300fps) with the Raynox converter. Am I correct here?
edit: The Raynox website claims that the 52mm threaded 0,7x wide-angle converter DCR-730 would work too without vignetting (of course I need an 52-62 adaptor). It would be half the price: about 75€ vs. 160€. But will it vignette using 300fps video or taking 6mpix pictures? 720p should be fine, as it is approx. 45mm from what I've read.
http://www.raynox.co.jp/english/digi...ASIO_EX_F1.pdf
http://www.raynox.co.jp/english/dcr/dcr730/index.htm
Janne Miettinen is offline   Reply With Quote
Old March 4th, 2009, 02:33 PM   #94
HDV Cinema
I'm not familiar with the SteadyTracker UltraLite, but please let us know how it works for you.
I'd go with the direct mount just cause it seems simpler. Your numbers seem correct and the 32mm would really be a big help.
Old March 4th, 2009, 04:32 PM   #95
The SteadyTracker UltraLite is really light and the EX-F1 isn't too heavy either. It should be a light-enough-combo to use for 20 minutes per hour. Or at least I hope so. :) I've read that SteadyTracker isn't optimal for panning, but I'll still try to use it for that. The next options are much more expensive, so I'll just have to see what kind of results I'll get with that combo.
EX-F1 will be my first video camera. It's time to see how a photographer can use his experience in the world of motion. :)
Here is a link to my website: Valokuvaaja Janne Miettinen - Häävalokuvaus, hääkuvaaja
Old March 4th, 2009, 06:38 PM   #96
HDV Cinema
Nice work. But what's Trash the Dress?
PS: I found out when I though the F1 was broken because it wouldn't focus -- that even left turned off for weak, it holds the Manual Focus mode!
Old March 9th, 2009, 02:35 AM   #97
What good and easy editing program should I use with h.264 video? I think Avids and Sonys programs are too complicated for me, because I'm a beginner in video editing. I would use Proshow Producer, but it doesn't support h.264. One solution would be to convert the h.264 into something the Proshow Producer understands, but I would rather use some other program.
Old March 9th, 2009, 04:31 AM   #98
HDV Cinema
Vegas Movie Studio and iMovie 09.
Old March 15th, 2009, 09:03 AM   #99
I've done some experimenting with this camera, and I think that the Dynamic Range adjustment doesn't affect the videos at all. I too like the look that Contrast +2 and Saturation +1 gives to the videos.
Old March 16th, 2009, 02:02 AM   #100
HDV Cinema
It does. It raises the upper IRE from 100IRE to 108IRE which you can see via HDMI, but likely not after editing which limits peak to 100IRE.
Old March 20th, 2009, 04:34 AM   #101
My EX-F1 doesn't seem to offer much better noise reduction in Portrait-mode than in other BS-modes (or when not using BS at all). Only solution to suppress low light noise seems to be to increase the contrast. Or am I missing something here?
Old April 10th, 2009, 08:35 AM   #102
Book
Could you ask Casio if they'd buy the book from you to promote the camera?
(the book would come not only as a manual, but an endorsement from the community of users IMO)
Laurentiu Todie is offline   Reply With Quote
Old June 18th, 2009, 05:55 AM   #103
New controller software is available!
EX-F1 Controller 1.000 Software Download: Casio Talk Forum: Digital Photography Review
Old September 13th, 2009, 07:15 PM   #104
I recently bought an EX-F1, largely for the high speed functions. But, I like to record HD movies. I do this in manual focus mode because this avoids the slight pulsing that you get when autofocus goes back & forth slightly around the desired focus setting.
The unfortunate thing about manual focus during video recording is that you cannot change the focus during shooting. So, if I'm shooting a video & I zoom in on something, I cannot adjust the focus. If you use autofocus, it will adjust focus when zooming, but the slight pulsing is undesirable.
Does anyone know if there is a way to manually change the focus during video recording?
Steve Paterson is offline   Reply With Quote
Old September 19th, 2009, 03:05 AM   #105
HDV Cinema
Pulsing of exposure or focus?
Steve Mullen is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > Photo for HD Video (D-SLR and others)
