FCP 6.0/HVX Log and Transfer trouble! - Page 2 at DVinfo.net
Old August 2nd, 2007, 05:50 PM   #16
re:
one workaround (albeit a slow one) for getting those pesky clips that log and capture didn't work on.
Use P2 Log demo as recommended and copy the files you want to a different folder (one folder for each movie file). Then create the subfolders for each individual folder to mimic to standard P2 structure. If you do that for each clips, they will always be the "first clip". Ex:
you have the following files:
2779BW, and 2762MW.
1. Create a new folder for each called CONTENTS.
2. Create the subfolder structure: AUDIO, CLIP, ICON, PROXY, VIDEO, VOICE.
3. Copy the appropriate files over. There should always be audio file, clip file, icon file , and video file.
Now when you're in P2 Log you have to seperate folders and the videos you want are the first one.
I only had three files i had to capture when doing this, so I was happy just to have a workaround. If you have tons you might not find it worth it.
Just a temporary workaround.
Josh Hayes is offline   Reply
