AG-HPX555 with SD lens <Clip available> at DVinfo.net
Old July 22nd, 2007, 01:42 AM   #1
I tested Canon J13x9B SD broadcast lens with AG-HPX555.
Here's a clip with various zoom positions shot with 720/30p.
http://www.brightminds.jp/component/...d,117/lang,en/
Kaku Ito is offline   Reply With Quote
Old July 22nd, 2007, 02:17 AM   #2
I added shallow depth of field clip.
Old July 22nd, 2007, 02:35 AM   #3
Kaku, I finally finished downloading the file a moment ago but can't get it to play in QT. I'm running Windows XP Pro, SP 2. Apparently I'm lacking the proper codec. Which one did you use?
Elizabeth Lowrey is offline   Reply With Quote
Old July 22nd, 2007, 02:43 AM   #4
Liz,
Sorry this requires Final Cut Pro installed thus DVCPRO HD codec gets installed for QuickTime. You are probably able to playback the H.264 thumnail clips that I posted in the description.
What would be the closest to native DVCPRO HD file for Windows? I can probably convert it for you.
Old July 22nd, 2007, 07:09 AM   #5
Raylight Decoder is a DVCPROHD Quicktime component for Windows
http://www.dvfilm.com/raylight/decoder/
Grigory Volovich is offline   Reply With Quote
Old July 22nd, 2007, 09:30 AM   #6
Thanks Grigory.
Old July 22nd, 2007, 11:30 AM   #7
Kaku,
How far away were you from the subject when you shot the shallow DOF (the plants) footage ?
Jason Strongfield is offline   Reply With Quote
Old July 22nd, 2007, 12:11 PM   #8
Jason, that was about 1 meter away from the one in the front and the where the silver stool is that is about two meters.
Old July 22nd, 2007, 12:15 PM   #9
By the way, the night shots with HD lens got moved to here.
