lens aberration and size of the ccd's at DVinfo.net
Old May 11th, 2007, 03:02 AM   #1
hi, i'm using the HVX200 and Boujou to track a motion, Boujou needs to know the lens radial distortion wich i've found to be 0.27 and also it ask me about the height and width of the sensor, does anyone knows what are those dimensions in mm? i'm asknig that because i don't know if the actual dimensions are the ones that Boujou needs or maybe the dimension the sensor should be (because the pixelshift, and the upzised resolution that goes in camera)
the standard sensor size that Boujou gives you is 14.7574x8.3007 is that right?
the radial distortion i've found to be 0.27
the camera shoots at 4:3 but i'm using raylight codec so the image ends up in it's correct aspect ratio 16:9 because of the ever changing format that the image suffer, i don't know which is the right information for Boujou
anyone can help?
Biel Bestue is offline   Reply With Quote
Old May 11th, 2007, 09:59 AM   #2
Barry Wan Kenobi
The HVX has a 16:9 sensor, not 4:3. And while nobody (AFAIK) knows the actual image sensor size, my guess is it's about 5.25mm x 2.95 mm.
Old May 11th, 2007, 01:44 PM   #3
thanks pal I'll try with that size
also
is there any tool to compensate the color aberration of the lense? some pluguin or some kind of digital compensator... i don't know...
Old May 11th, 2007, 03:32 PM   #4
There is no way it's that small. 3mm? No way.
Gene Crucean is offline   Reply With Quote
Old May 11th, 2007, 04:30 PM   #5
Barry Wan Kenobi
The normal size for a 1/3" sensor, in 4x3 terms, is 4.8 x 3.6 mm. Why would you think 5.25 x 2.95 is too small?
