HVX202 firmware to support 16GB P2 cards at DVinfo.net
Old May 10th, 2007, 07:18 AM   #1
Hi all,
The HVX202 firmware is already available since yesterday. I have downloaded it, installed into my HVX202 without any problems. But I can't test - because I don't have any 16GB P2 cards yet.
Please note that P2Store also requires a firmware upgrade to understand the 16GB card - and that is still NOT available.
If your HVX200 or HVX202 is of the latest version, then you don't need the firmware upgrade. Check the version that is inside your camera. My was 2.05, the firmware is 4.05.
TS
TingSern Wong is offline   Reply With Quote
Old May 10th, 2007, 10:05 AM   #2
A couple of new items are added including an hours counter under other functions, I believe.
David Saraceno is offline   Reply With Quote
Old May 14th, 2007, 09:51 PM   #3
Any link to the firmware ?
Gonzague Alexandre is offline   Reply With Quote
Old May 14th, 2007, 10:28 PM   #4
Link is here ...
https://eww.pavc.panasonic.co.jp/pro...ain/soft_e.htm
Click on HVX202 ...
Download the PDF, print it out, and read it before you upgrade.
Old May 16th, 2007, 07:06 AM   #5
Thanks you, I will read the PDF first ;)
Old May 16th, 2007, 09:30 AM   #6
there is no pdf apart from the release notes which only mention 16gb support.. anyone know of any other tweaks? or where i can find a list of actual additions?
Peter Jefferson is offline   Reply With Quote
Old May 16th, 2007, 10:20 AM   #7
Hi,
The PDF is here ...
https://eww.pavc.panasonic.co.jp/pro...soft/upg_e.htm
Under "Installation Procedure" :-)
TS
Last edited by TingSern Wong; May 16th, 2007 at 10:21 AM. Reason: Forgot to include the heading
Old May 16th, 2007, 08:13 PM   #8
Barry Wan Kenobi
There's not much else different that I can detect; there's an hour meter, and there's a new repair-clip function called "repair clip (loop)". Other than that it seems to be the same.
Barry Green is offline   Reply
