Is there an aftermarket D-Tap cable that doesn't suck?! at DVinfo.net
Old April 27th, 2007, 09:54 PM   #1
Hi,
Is there such a thing as a D-Terminal to Component cable that FIRMLY attaches to the HVX?
I'm willing to grin and bear it with bongo ties or gaff tape... until I start loosing video feed during every other take, causing the director to yell at the camera dept. and a producer to pull me aside (which is exactly what happened on the last shoot I was on). My patience runs out when my job security is in question.
So does a good cable exist? If so, where do I get it?
(Feel free to PM me if I have to go to a non-sponsor)
Many thanks,
Matt Irwin
DP / matt.irwincine.com
Matt Irwin is offline   Reply With Quote
Old April 28th, 2007, 02:18 AM   #2
Yes, please let me know if there's anything out there.
Jon Wolding is offline   Reply With Quote
Old April 28th, 2007, 11:49 AM   #3
What would be great is a block-style adapter that mounts solid to the D-Tap, then has 3 BNC compnent connectors pointing straight back along the camera. It would live semi-permanantly on the body like compact video-tap on a film camera. No cables, no strain, just a hard plastic block. Someone manufacture that, please?
You could go even further and split the output to S-Video, Composite BNC, an additional Component out... then you could actually have more than one active output! What a concept...
Matt Irwin
Old April 29th, 2007, 08:22 PM   #4
Go Go Godzilla
Images: 15
Matt,
With the size limitations of the HVX form factor, heavy-duty connectors on all the I/O options would require a lot of real-estate both exterior and interior which just isn't available on the current HVX design.
The HPX500 however, has more robust connectors for everything, even the rear FW port is reinforced.
Old April 30th, 2007, 02:34 AM   #5
Understandable, but surely a D-Tap connector could be made that firmly mates with the port on the HVX, instead of loosely "hanging on"...?
Matt Irwin
Old April 30th, 2007, 08:07 AM   #6
Go Go Godzilla
Images: 15
Actually the key phrase for this issue has always been, "strain relief". Even on ENG or film cameras we always tie up/off all cables going into the camera or the accessory packs. Even though some connectors such as XLR are very robust they're not designed to take the load of a long cable tugging at the connector while the camera is moving or - god forbid - somebody walking by and tripping on a cable.
So while the small-ish D-connector on the HVX isn't very robust in it's connection you're always going to be best off putting some form of strain/stress relief on that cable.
Robert Lane is offline   Reply
