How to get rid of Motion blur on fast moving object? - Page 2 at DVinfo.net
Old March 25th, 2007, 09:49 AM   #16
Originally Posted by Gonzague Alexandre View Post
Ok but....
on a HVX we have different shutter speed like 500, 1000 or 2000... but when you are in 30 or 60... I cannot use those higher setting ?!?!? I am confuse
Lets see if I have a 500 shutter speed in order to respect a full digit rule (no number like 1.33) I must have a 25fps, 1000 a 50... How can I do that.... I am really lost here
You can use the higher shutter speeds if you want a "Saving Private Ryan" effect. They can work with water spray when you want a sharp strobe type effects on the water droplets. However, if shooting you're at 24p, 30p or 60p the high shutter speeds should be regarded as an effect.
The standard shutter speeds are 1/48, 1/60 and 1/120 respectively, if you go higher than these you need to aware that you are increasing the jerkiness of the action.
A car moving through a static shot doesn't need a high shutter speed. You're not trying to freeze action as stills photographer does, the motion blur smooths the action.
If shooting progressive, make sure the shutter is switched on.
Old March 25th, 2007, 09:54 AM   #17
'Cannot' ...
You can always use high shutter speeds when the subject is motionless. And in general, if the object is moving towards or away from you, you can use much higher speeds than if the subject is moving laterally. And if the object is distant, you can use a higher speed than if it is close ...
As for the full digit rule ... I don't know where you are going with that. In general, shutter speeds are in full stop increments -- each notch halves the speed, and so drops the exposure by one full stop. But there is no rule in that -- if the speed dropped by less than half, the aperture would open a little to keep exposure accurate. 30/60/125/250/500/1000 is not essentially any different than 25/50/125/250/500/1000 ... the percentage 'jump' from 50 to 125 is mildly significant, but once done the rest of the values hold.
HTH
GB
R Geoff Baker is offline   Reply With Quote
Old March 25th, 2007, 11:06 AM   #18
You're better using neutral density filters for controlling exposure rather than shutter speeds.
Old March 25th, 2007, 05:11 PM   #19
Thanks Guy... I need to play more and to more test until I reach the perfect setting... unfortunately time is always my enemy...
Once again Thank you for your kind help
Gonzague Alexandre is offline   Reply With Quote
Old March 26th, 2007, 01:53 AM   #20
If sound is not important, I would suggest shooting 30pn with 60p slowmotion. Than speed up in post (double speed). Shutter at either 125 or 250. Try this out.
As for native 30pn, if you don't want the moving car to stutter, try Panning with the car CENTERED. The scenery will blur, but the car will stay sharp. Shutter speed of 125 should be the further you go.
And do turn OFF OIS, like the fellow DVInfo member pointed out. OIS adds a layer of blur, EDIT much noticeable in FILM LIKE Progressive frame rates- 30p, 25p or 24p . It was designed to work in Interlaced modes, EDIT or smooth progressive frames like 50p or 60p, not in film like frame rate modes.
If you don't believe in your film, no one else will.
Sergio Perez is offline   Reply With Quote
Old March 26th, 2007, 04:28 AM   #21
Why would an 'Optical Image Stabilizing' system care if you were shooting interlace or not? What 'layer of blur' could the moving lens of the OIS system introduce?
Turning off OIS to smooth panning makes sense, if the OIS is sensitive to the rate of pan ... but frankly, rest sounds like nonsense ...
GB
Old March 26th, 2007, 04:45 AM   #22
GB
Well, what I meant was that OIS affects image movement you're recording in a progressive mode that's bellow 60p or 50p. OIS compensation for movement seems to add a layer of compensation thats visible in these frame rates. In interlaced 60 i and 50 i footage, this is also a non-issue, due to the natural smoothness of the image. It can add a small layer of softness in pans, but not much noticeable.
That's what I meant. 60p/50p frame rates also work fine with OIS. Its just when you're working with film frame rates that OIS looks particularly bad. Saying only interlaced was my mistake. I wanted to say OIS works particularly bad in FILM LIKE frame rates, slower than 60p or 50p-make it 30p, 24p or 25p.
Nonsense?
Old March 26th, 2007, 05:21 AM   #23
Maybe nonsense is harsh -- I surely didn't mean to stifle discussion.
But I fail to see how an optical lens, tilting in response to axis movement of the device ... can add a layer of anything. The lens tilts in and the image is respositioned on the sensors. The sensors, and the encoder, are 'dumb' to the action of the lens -- the reason to turn the system off during a pan is mechanical ... the tilt defeats the movement of the pan momentarily, then gives up and the image jumps to the new position, then the system tries to defeat the pan, et cetera. It is only because the OIS doesn't 'know' that you intend to move the image that it fights you.
But try as I might, I can't make sense of the rest of your description of the operation of the optical image stabilizing system. It is blind to frame rates, it doesn't add layers of anything, it is a 'simple' optical mechanical device, rather like a tripod's fluid pan head ... and simply can't be responsible for the effects I understand you to be describing.
GB
Old March 27th, 2007, 08:17 PM   #24
Mr Baker:
Your description of the OIS system is correct, but what I mean by the "Layer of compensation" is what you describe. This adds extra strobe while panning and tilting. In 25p, 24p and 30p, this is much noticeable. In 60p/50p and 50i/60i, this is a non issue- maybe you can get a small tilt or jump from OIS compensation, but its not a major constant problem. I do not know how to give you a technical description of the effects in 25p or 24p, but the actual results are as I described. I would certainly be more than happy to post some footage about this.
Old March 28th, 2007, 05:58 AM   #25
If you could post footage, I'd be most interested in seeing it.
Cheers,
GB
Old March 28th, 2007, 10:44 AM   #26
The only blurring I saw looked like de-interlacing artifacts...or slow-mo frame blending. Every couple of frames, the image seems to ghost...step through it and watch the edge of the license plate.
Web Youtube Facebook
Cole McDonald is offline   Reply With Quote
Old March 28th, 2007, 10:49 PM   #27
Cheers,
GB
I'll do that. Need some days tough- going abroad for some event coverage, be back in a week.
Old April 1st, 2007, 12:34 PM   #28
GONZAQUE,
If your problem is "shudder" related / try this link on motion / movement /
shutter / shudder etc.
http://hd24.com/dont_shudder_at_the_judder.htm
Herman.
Herman Van Deventer is offline   Reply With Quote
Old April 1st, 2007, 05:38 PM   #29
Thanks, did not had time to play with my HVX lately, but will surely read !
