1080i vs 1080i 30p at DVinfo.net
Old March 5th, 2007, 03:57 PM   #1
1080i vs 1080i 30p
I'm new to the camera and despite a great deal of reading, am confused about the formats. I'm about to shoot some nature and ocean footage, will edit in FCP and hope to some day output to Blue-Ray or HD DVD. Which format should I use - 1080i or 1080i p30? Is there an advantage of one over the other? I cannot seem to find the answer and would greatly appreciate your help.
Thanks in advance. Barry
Barry Bittman is offline   Reply With Quote
Old March 6th, 2007, 06:09 AM   #2
What is your goal?? I would look at the 1080 24pA mode as well.
1080 30p will produce a more fluid video look. At this point I would not shoot 1080 60i....The interlacing might be evident on progressive displays.
Mike Schrengohst
dvd.pro@verizon.net
Mike Schrengohst is offline   Reply With Quote
Old March 6th, 2007, 06:40 AM   #3
1080i 24P HDV worked to get rid of interlace artifacts
I recently had similar issues. It was a simple solution. Shoot 24P. The only way I could be assured of no interlace artifacts was to shoot 1080 24P. Having come from a "film based" background I have a lot to learn about video.
I have not tried it yet, but it was also recommended to shoot 1080 30P and bring it into a 60i timeline.
If there is a recommended work flow in 30P I would appreciate knowing what it is. (HDV to DV for DVD and WEB publishing) Also the slow-mo in this setting does not work as well as 60i but that's another problem I will have to solve.
John Huling is offline   Reply With Quote
Old March 6th, 2007, 02:19 PM   #4
1080i 24p captures 24 progressive frames and doles them out to 59.94i. If you want filmlike cadence and want to go back out to broadcast this is for you.
1080i 24pa captures 24 progresssive frames and doles them out to 59.94i with a removable pulldown to edit and deliver at 24p, film or progressive dvd.
1080i 30p captures 30 progressive frames and doles them out to 59.94i Nice for Docs and such where cinema cadence is perhaps to jarrring but full on 60i is too videoish.
1080i 59.94 Good for sports, reality, and fast motion. With 59.94 you can use higher shutter speeds without the exaggerated motion effects of the progresssive modes.
All of these modes save the pa should be imported and edited in a 59.94i timeline. For the pa mode import into a 23.98 and remove duplicate frames on import.
Good Luck, Charles.
Charles Hurley is offline   Reply With Quote
Old March 6th, 2007, 02:53 PM   #5
Charles
If yuo go 1080i 60 how do you get rid of the stairstepped edges/interlace that it creates? I managed to rid myself of "them" by going 1080 24P
Old March 6th, 2007, 05:50 PM   #6
Thank You
Thank you for taking time to answer my question. Unfortunately, there isn't a great deal of understandable info available on this topic. I really appreciate your perspectives. With appreciation, Barry
Old March 8th, 2007, 02:19 AM   #7
John. 1080i at 59.94 in inarguably the smoothest form of playback available for the hvx. What are you talking about specifically. If you import your 59.94i footage into the proper sequence there shouldnt be any artifacts interlaced or otherwise. You might double check your settings. Good luck.
Old March 8th, 2007, 06:29 AM   #8
Charles
Thanks for the comment. When I shot a 15 sec clip just for a test in HDV 1080 60 >Captured to FCP as 1080 60 in the timeline saved as a self or ref QT mov (also went straight to Compressor made no difference) Opened in Compressor and submitted as a 90min best SD. Made a DVD in DVD Studio Pro and or a QT web movie. Viewed the image on a 26 inch Sony HDTV monitor and computer Screen. The video always exhibited jagged edges, stair stepping, interlace. As soon as I went with 24 P it was gone. I consulted with several different "certified experts". The advice that worked for me was 24P. If you want to email me a detailed work flow from shooting to web and or DVD that does not have any jagged edges let me know. I fiqured if the guys I spoke with could not fiqure it out I certainly was not going to be able to.
Old March 8th, 2007, 06:08 PM   #9
I tried it and got interlacing artifacts as well but I supsect they wouldn't be there if I were using an interlaced CRT. Just make it easy and shoot 24p or 30p. No interlacing=No interlacing artifacts. 1080i will be gone in a couple of years anyway. Good Luck.
Old March 12th, 2007, 12:18 AM   #10
Well actually, 1080i is not going away any time soon as there is no planned broadcast support for 1080p nor do most of the networks care to go there. As it is they are playing bit rate reduction games, not caring much about picture improvement.
Movies yes, HD-DVD, Blue-ray yes. Broadcast/cable television no.
Gary L Childress is offline   Reply With Quote
Old March 12th, 2007, 05:30 AM   #11
Originally Posted by Gary L Childress View Post
........there is no planned broadcast support for 1080p nor do most of the networks care to go there.
Not for 1080p as such, but for 1080psf there most certainly is. ("Psf" = "progressive, segmented frame"). As long as you are happy with 24/25Hz motion ("film look") that's a way of carrying a true progressive picture over an interlace transmission path, and is how most drama etc programming is seen in Europe. And for sport etc just use the chain in interlace mode.
Old March 13th, 2007, 11:03 PM   #12
You're right, the networks don't care at all about compression efficiency or next generation formats. I worked a gig today for Miramax where they talked about reintroducing VHS as the future of broadcast.
