Good Backpack for HVX + gear at DVinfo.net
Old January 1st, 2007, 11:20 AM   #1
O.K.
I am doing some hikes soon with my camera and gear:
HVX200
P2store
5 Batteries
Monitor (deciding between Swit and Marshall)
A few screw on filters
mic and cables
tripod
Rain slicker
I bought the petrol bag said to fit the hvx and gear, and am a little concerned with how little room there actually is for the gear. everything is cramed in it seems, since this is baisically just a storage/light duty bag it is fine, BUT I am concerned that the packs that claim to fit the HVX will do just that, fit the HVX and not much else.
What packs have you all used WITH gear?
I am looking for somthing that will withstand actual trail use, fit all my gear safely, be water resistant, and have a proper fit (on me)
Suggestions?
Last edited by Phillip Palacios; January 1st, 2007 at 11:22 AM. Reason: descriptive title
Phillip Palacios is offline   Reply With Quote
Old January 3rd, 2007, 02:38 PM   #2
Kata?
I found this on B&H:
http://www.bhphotovideo.com/bnh/cont...ughType=search
does ANYone have input on this?
Phil
Old January 3rd, 2007, 04:01 PM   #3
Usually out in Yellowstone I take along a Lowe Super Photo Trekker.
--==Kevin==--
Old January 4th, 2007, 02:41 PM   #4
Go Go Godzilla
Images: 15
Philip,
I recently went pack-shopping myself but didn't want to spend hundreds of dollars on a "camera specific" pack and came up with a very cost effective solution:
REI has a variety of general use backpacks that will work very well. I found one (can't remember the model name and it doesn't say anywhere on the bag) that has room for the following:
- HVX mounted on Zacuto base-plate with extended rods fore & aft
- Panasonic BT-LH900 monitor
- (2) Endura 10s V-mount batts (for monitor)
- (3) HVX batts
- Matte-box and 2 square filters
- Varizoom ROCK-PZFI controller
Unlike the packs that come with built-in separators like camera cases do, I've just wrapped each item in either foam or bubble-wrap to keep them from bumping into each other in each compartment. I was most concerned with the monitors' face being scratched by something during transport so I taped a piece of cardboard over the face and then wrapped it in foam with a rubber band to hold the foam in place.
The REI bag was $100 and has 6 layered compartments
Old January 4th, 2007, 05:04 PM   #5
Id stay away from that KATA one from BH. Its good with pockets, protection, etc, but its huge! Its like having a giant turtle shell on your back. I had mine, used it once, ended up selling on ebay last year when I was using a xl2 with it. I second the REI bag idea, I use a Northface bag, that was around $100-$125 or something and its great. And there are so many levels-sizes-colors-types of those type of packs, I am sure you can find something that works best. And in the end of the day, you still have a pack that can be used for other purposes outside of camera use. I usually put most my extras, filters in front or side pockets, and carry my SLR and HVX200 together in main area.
Michael Younger is offline   Reply With Quote
Old January 5th, 2007, 07:14 AM   #6
Thanks guys,
I will be heading to my local hiking gear shop to check out what they have.
I will probably end up puting all the gear in sealline saks inside the pack for water protection (tropical downpours and such).
Thanks again,
Phil
