FS-100 v2 at DVinfo.net
Old November 14th, 2006, 02:28 AM   #1
FS-100 v2
Does this firmware update allow 24pn as well as slow motion? Did anyone have any experience with it yet? All it says in the read me file is "Improvements for 24P support" which doesn't really say alot...
Dennis Davidoff is offline   Reply With Quote
Old November 14th, 2006, 11:18 AM   #2
Interested also.
Gene Crucean is offline   Reply With Quote
Old November 14th, 2006, 03:16 PM   #3
Its impossible for FS to use 24pn, or any other native mode, because HVX does not send native modes to Firewire.
Dick Campbell is offline   Reply With Quote
Old November 14th, 2006, 03:30 PM   #4
Barry Wan Kenobi
Version 2 does not support 24pN "simulation", but version 3 will.
The HVX does not output any data from the FW port when in 24pN mode, but the FS-100 v3 will record only the "native frames" from the firewire stream, discarding all the other frames. So the net effect is the same as if you'd shot in 24pN. DV Rack HD and EDIUS and FCP all do the same thing, and with V3 of the software FS-100 will also offer this capability.
Old November 15th, 2006, 12:30 AM   #5
So when does the V3 come out? Any news on that? I thought V2 just came out.
Old November 15th, 2006, 08:17 AM   #6
Not really. The reason I want to be able to record in pN is so I can overcrank. What you just described won't let me do that.
Old November 15th, 2006, 09:26 AM   #7
Barry Wan Kenobi
Yes it will! That's exactly what it will allow.
But you don't need to wait for that, you can overcrank with the existing FS-100; you just need to strip out the duplicate frames using Apple's FRC.
Old November 15th, 2006, 10:13 AM   #8
Hmm. I was under the impression that you can't even set the camera to overcrank unless you were in pN mode. So basically you're saying that you can overcrank in regular p mode and the fs-100 will record it?
If this is the case, say no more because I'll have my checkbook out in 5sec to finally buy one of these. This has been the killing point for me for a long time.
Thanks for the clarification too btw.
Old November 15th, 2006, 11:06 AM   #9
Barry Wan Kenobi
Yep.
The only thing is, you won't see the slow-mo effect upon playback, you have to process the footage through the FRC. Which is the exact same thing you'd have to do if you shot VariCam too.
Old November 17th, 2006, 07:47 AM   #10
What's FRC???
So if you want to over or undercrank, FS-100 will not receive through FW from the HVX, native frames.Unless FRC???? What's FRC??
Daniel Gervais is offline   Reply With Quote
Old November 18th, 2006, 06:27 AM   #11
Frame Rate Converter.
"There are 10 types of people in the world:
Those that understand binary, and those that don't!"
Dee Joslin is offline   Reply
