HD to SD authoring question
Well, I am moving from shooting in the field to shooting myself in the foot in edit. I am trying to put my reel together -shot and edited in a 720 24pn timeline in FCP 5 and now I want to produce a DVD that will retain the 16:9 aspect ratio of my project on a regular old 4:3 TV.
I exported a self contained QT file and imported that into Compressor w/aspect ratio set to 16:9 and imported that into DVDStudio Pro, built my project and exported using a 16:9 aspect ratio but that didn't work. So I tried exporting from compressor in a 4:3 ratio. Still no luck. I know I have to convert to 4:3 sometime, but when? I read on some edit site last night that I have to make a new DV-NTSC sequence in my 720p FCP timeline and nest my project in there before exporting it to Compressor in order to do what I want, but that hasn't worked for me either. I know I must be overlooking something fairly simple here, but I'm darned if I know what it is... |
Under Preferences:General:
SD DVD Menus Tracks, menus and slideshows: 16:9 Letterbox Also Simulator: Playback Output:SD 16:9 And: Encoding: MPEG SD: Aspect: 16:9 And when you run a simulation you may have to select 16:9 Using these settings should produce a 16:9 DVD that will play full-screen in a 16:9 display and Letterbox in a 4:3 TV..... Most of my clients seem to run DVD's from a computer and progressive HVX footage formatted 16:9 looks fantastic...... |
Deleted my previous answer. Just make sure that your track is set to 16:9 in the inspector.
Douglas Villalba - director/cinematographer/editor Miami, Florida, USA - www.DVtvPRODUCTIONS.com |
For letterbox:
Open up your 720 timeline, select all, copy, then open up your 4:3 timeline, paste, render, then output. Anamorphic 16:9 isn't compatible with all DVD players (in my experience), so I make everything letterbox. |
#5 |
You are right....
On short projects I usually make a 4:3 and a 16:9.... But as time goes on the majority of Tv's will be LCD, plasma etc 16:9..... |
#6 |
Thanks guys.
Not sure why exactly, but out of 3 different dvd players, none of them would display my 16:9 letterbox formatted disk in anything other than 4:3. I was attempting to follow sam's advice and make a new sequence w/DV NTSC 4:3 setting, but I neglected to choose the dv-ntsc 48khz 24p setting from the dropdown, which prevented me from importing those clips into that new seqeunce in the timeline. Not sure if it's a menu setting that needs to be adjusted in each of those players, or if stamped dvds from an authoring facility behave diffrently from the ones I can burn, but I was pulling my hair out because on my computer the disk would play in 16:9!! Anyhow, I think I'm clear that I have to band those black lines in FCP as you said and keep the rest of the project 4:3 throughout compressor and FCSP. |
#7 |
Most DVD players will display 16:9 material as letterbox....
even my cheap $39 Walmart special will??? Most of my clients use DVD running off of their computers and they all will display 16:9..... If coming from 720 24pN - try dropping your show in a DVCPRO 50 24p timeline....the finished DVD will be much cleaner than going into a DV timeline.... |
#8 |
Ha, I think the units I tried were remainders from 5 years ago- one Panasonic and a Sony. The Toshiba player is only a year old, a real crappy VHS/DVD combo unit that I up and ripped out of our rack today. What a hunk a junk.
Walmart here I come. Thanks for the DVCPro50 suggestion. My client is my boss (hey, who's ain't), so I need to impress. Thanks again. Brian |
#9 |
dvd authoring
Does anyone know how to charge for this like say weddings?
thanks in advanced shawn |
