double-checking on file org issue at DVinfo.net
Old September 7th, 2006, 05:41 PM   #1
I know the LASTCLIP file is critical to FCP, as well as the overall CONTENTS folder directory path, but in situations where two clients' material is on the same card, I want to make sure nobody's having problems making two copies of the P2 card, then deleting the appropriate media from each copy, to create two client-independent folders. I see that the thumbnails for the deleted media still show up when I do this (I guess there's a jpeg stored somewhere even though the 200 doesn't generate true proxies?) but it appears that the remaining media will import fine. I never knew whether the LASTCLIP file was tightly linked to the ~entire~ contents of the card, or if it just needed to be there for any mxf files to import correctly.
(I suspect this is in Barry's book... ahem... but I haven't finished it, and I'm on location at the moment.)
Anyone else been doing this?
DP/Editor, Sputnik Pictures | Atlanta
HD video and RED digital cinema production
Scott Auerbach is offline   Reply With Quote
Old September 9th, 2006, 04:14 PM   #2
Anyone??? :-)
I know the recommended method has been to keep everything from a card's contents folder together, but the one time I've tried this, it worked. I'm trying to figure out if I just got lucky, or what?
