Hvx Dv Audio The Same As P2 Audio at DVinfo.net
Old August 29th, 2006, 11:26 PM   #1
Hello, I’m Shooting An Instructional Video On A Green Screen, Only Using The Narrator On Screen For A Few Minutes Throughout The 45 Minute Script. Having Only One 8g P2 Card, So I Was Thinking I Could Record 45 Minutes Of Audio Using The Hvx In Dv Format, Delete The Video Track In Fcp And Use Just The Audio, Then Shoot Bit's And Pieces Of The Narrator Using The P2 Card At 1080 With The Same Shotgun Mic And Audio Settings, Use The 1080 Footage And Audio Of The Narrator And The Rest Will Be Dv Audio For The 1080 Instructional Footage. Will This Work? Will The Audio Sound The Same?
Scott McKechnie is offline   Reply With Quote
Old August 30th, 2006, 12:12 PM   #2
I don't know if the end processing is identical, but all of the important parts (room, mic, preamp, A/D converter) would be the same. Even if there is some minor processing difference, I doubt that anybody in your audience would ever notice.
Jon Fairhurst
Old August 30th, 2006, 05:26 PM   #3
In HD and in DV the camera records uncompressed 48 kHz, 16-bit PCM audio.
Unlike HDV which records audio compressed at a ratio of 4:1 using MPEG-1 Layer II audio compression. Those cameras record 48 kHz, 16-bit PCM audio in DV mode.
On that issue people say there will be no difference perceptible to most people - others say they record dual system when shooting HDV.
So - as the hvx records 48 kHz, 16-bit PCM audio in both modes then one would expect no noticible difference.
Bill Brown is offline   Reply
