Question about P2 Log and aspect ratio at DVinfo.net
Old August 28th, 2006, 09:35 PM   #1
hello,
I'm wondering if anyone is experiencing the same things using P2 Log from imagine products.
It looks like every-time I export to FCP XML then import the XML file in FCP, the 720p clips (did not try 1080 yet) show up with the wrong aspect ratio (square) it's easy to fix by selecting all the clips in my browser, control click the aspect ratio column and select "HD 960x720" or should I leave it in square and check the anamorphic column ? which seems to so same thing.
Any way to avoid this steps ?
thanks
Sights Sounds Stories
www.tinboxtwo.com
www.reardenstudios.com
Eric Peltier is offline   Reply With Quote
Old August 29th, 2006, 08:59 AM   #2
Have you contacted the company?
It is pretty responsive.
David Saraceno is offline   Reply
