Powering the HVX with A/C at DVinfo.net
Old August 14th, 2006, 10:26 AM   #1
Not to beat a dead horse, but I wonder if I'm doing something wrong.
Maybe I've just forgotten how to read, or I'm even more ignorant
than I give myself credit for ;)
When powering the HVX from an A/C outlet, page 17 of the HVX User
Manual shows how to connect the battery adapter to the cam.
However, located within the cam body, there is also a "DC Input Terminal"
for 7.9 V. (See "Description of Parts", pg 12, item 30).
Obviously that's for a direct DC power feed. Is there a typical
"brick" adapter/converter that allows use of that terminal?
Might using it cause some damage or other problem?
I have some Spec Comm batteries and their charger. I noticed there
is an empty spot in the charger for a 7.9 V terminal, but that's
not the model I got.
Did I screw up by not getting that model?
Denis
Our actions are based on our own experience and knowledge. Thus, no one is ever totally right, nor totally wrong. We simply act from what we "know" to be true, based on that experience and knowledge. Beyond that, we pose questions to others.
Denis Danatzko is offline   Reply With Quote
Old August 14th, 2006, 04:04 PM   #2
I have two Panasonic charger/AC supplies which both work with the 200. Both of them come with a 'paddle' that mates with the battery socket. But I'm sure there are aftermarket AC-to-DC power supplies that output 7.2v (despite the stated 7.8, 7.2v will work on the HVX) to a ring-sleeve connector. They were probably just trying to offer another means of providing power. The advantage of the paddle is that it clicks into place like a battery. A ring-sleeve plug wouldn't.
DP/Editor, Sputnik Pictures | Atlanta
HD video and RED digital cinema production
Scott Auerbach is offline   Reply
