What does 480p30 (over 60i) mean? at DVinfo.net
Old August 9th, 2006, 08:21 AM   #1
Does this mean that the 480p30 isn't true progressive? That you edit it in the timeline as interlaced?
Bill Edmunds is offline   Reply With Quote
Old August 9th, 2006, 10:49 AM   #2
I read that as an odd way of saying how the image captures progressive frames in a video stream. The true progressive video stream is carried in a 60i signal and then combined to make the correct image.
Kyle Doris is offline   Reply With Quote
Old August 9th, 2006, 10:50 AM   #3
Originally Posted by Kyle Doris
I read that as an odd way of saying 3:2 or 2:3:3:2 pulldown. The True progressive video stream is carried in a 60i signal, using one of those two techniques.
That sounds reasonable. Do you know if you edit it as interlaced or progressive as far as your timeline settings are concerned (field dominance in other words)?
Old August 9th, 2006, 03:36 PM   #4
Barry Wan Kenobi
You edit as progressive. In an editor like Vegas, when you choose field options you get a) upper first, b) lower first, or c) none - progressive.
Barry Green is offline   Reply
