#61 |
Go Go Godzilla
Cees,
If you can't see the shirt buttons (that is a black-on-black area) then your monitor definitely needs calibrating. There isn't a ton of detail in that area since the lighting was concentrated for skin tones and showing the lenses on the table, the buttons are very noticeable. Without knowing what kind of monitor you're using (CRT, LCD etc) pr which system PC or Mac, I can't give you any guidelines for proper balancing, but I'm sure one of the forum members can give you a quick guide for proper color/contrast balancing on any setup. |
#62 |
A beer garden? A garden full of beer? Sounds good. I'll send you an email. Busy this upcoming weekend, but I'll be in touch.
Mark Sasahara Director of Photography |
#63 | |
Neither of the above, though I did have Les for M&P. It was one of my 2nd year teachers (whose name I've spaced out at the moment). I came through PPHL (that's what the degree is in) but majored in film and tripled up on Multi-Image (remember 16-projector slide shows?... shudder....). I'm also unusual in that I was able to arrange getting Brad Hindson as my primary faculty guy for Photo Ill, even though he was technically assigned to the Photo-Fine Art program (with Bea Nettles). Brad was the only one there who really specialized in visual-diary-with-Leica shooting (think: Horace Bristol, Mary Ellen Mark, Erwitt, Uzzle, Nick Nixon). As for the Rochester suicidal winters....that's what Lexapro is for! It's also for those of us who sit in a dark edit suite day after day (and that's coming from personal experience!) But I'm leading us off-topic... sorry 'bout that, folks!!!
DP/Editor, Sputnik Pictures | Atlanta HD video and RED digital cinema production |
#64 | |
I wonder what your workflow problem with the H1 is? Do you normally edit in a 720 60p timeline with 24p over 60 frames, or do you usually work in a 720 24 timeline? Have you tried taking raw .m2t's and converting through MPEG Streamclip to DVCPro HD? They can look good at both 1080 24/60i DV100 or even better as 720 24/60p. It's easy to downres Canon 24F to 720 24 and with a Natress plug-in (Standards Converter/Map Frames) it's also pretty easy to convert 1080i to 60p. If you have a fast G5 the conversions can be very fast. You could always get a little mini-Teranex for instant standards conversion via SDI but the MPEG Streamclip program produces amazing results for free. |
#65 |
Go Go Godzilla
Barlow,
What it amounts to is that trying to merge H1 footage with HVX means more work, no matter how you look at it. So, rather than make more work for myself on this big project I'm just going to stick with what I started with - the HVX. Trust me, I'm not lamenting not getting the H1; it was supposed to be a stop-gap for certain types of work but I'm much better off (and more comfortable) staying with true 24p and 4:2:2. I've already put my pre-order in for the HPC2000, so between that and the HVX I'll be 100% covered for everything I shoot - with exception to those jobs that are best suited for film. The 2 Pannys along with the new Mac Pro is just ordered (KONA drivers to be available late this month) I'll be in HD heaven - for a while at least. (^_^) |
#66 |
Understandable. Good for you and good luck with your project. :)
#67 |
Go Go Godzilla
Color Update
I just realized today that my previous landscape tests were bungled - I completely forgot to adjust certain settings which would have drastically altered my results - and even made the studio work even better. Crap! Oh well, this entire process has been one massive learning curve.
So, along with the 2 new tests I mentioned in the newer thread, I'll also be posting results from this new round of landscape tests with updated camera settings. Weather permitting I'll be shooting first light tomorrow and posting later the same day or Friday. |
#68 | |
#69 | |
#70 | |
Go Go Godzilla
But seriously, I went over my result notes and realized that I completely forgot to adjust some pretty important settings such as KNEE, PEDESTAL, CHROMA and RGB balance. My initial testing plan did cover those setting adjustments however, I became distracted by some strange ND and CIR POL results I was getting and completely glossed over those extra settings. Can you say, "brain fart"? I need an assistant! (laughs) |
#71 | |
California shootout: http://www.dv.com/features/features_...leId=177103305 |
#72 | |
-and yes assistants are great- |
#73 | |
As for me, it's starting to look like my next camera purchase will be either the new Silicon Image camera or RED. And between one of those and the HVX, I should be set.
- Jeff Kilgroe - Applied Visual Technologies | DarkScience - www.darkscience.com |
#74 | |
I can say the same : whithout mentioning all the settings you used on the HVX when you shot landscape scenery forum members can not give you a quick guide for proper handeling the HVX.
edit : I just saw your last threads where you admitted it was just poor handeling. Quote:
#75 |
Wow, the power of words. If any of you are in doubt about the HVX....
http://www.motionzonehd.com/files/fo...d/VIDEO_TS.zip This is a demo that I did for my site and Panasonic is also using it. Regional sales reps have a disc that contains the CONTENTS folder that they can copy to a P2 card. It's the same demo as the DVD. The VIDEO_TS folder can be un-zipped and burned to a DVD. It is SD but gives a good indication of what you might expect shooting HD then producing SD DVD. The footage is a mix of 720 24p, 720 30p and 1080 24p. |
