1080p vs. 720p - Page 2 at DVinfo.net
Old June 16th, 2006, 10:18 AM   #16
Originally Posted by Brad Abrahams
DVCProHD horizontal luminance is actually 1280 for 1080p, not 1440. HDCAM and HDV are 1440.
Whoops, sorry. Not that it changes the point - that figure represents 33% higher than 720 DVCProHD, giving some leeway which the HVX should be able to utilise via pixel shifting. Since commonly available displays are typically 1200-1400 horizontally, the difference should be noticeable.
Old June 16th, 2006, 11:37 AM   #17
Barry Wan Kenobi
In the US version it's 1280; in the EU version it's 1440.
Old June 20th, 2006, 04:42 PM   #18
Does this mean that the PAL version has a better res than the US?
Glen Johnson is offline   Reply With Quote
Old June 20th, 2006, 07:25 PM   #19
Barry Wan Kenobi
Probably not, but I'd have to test them side by side to know for sure.
As is, the recorded image on the US version very closely matches the live camera head feed, so it seems like the 1080p mode can effectively record all the detail the camera head can give it. So having more pixels in the recording mode won't necessarily lead to more recorded detail.
Old June 21st, 2006, 10:21 AM   #20
Originally Posted by Betsy Moore
Phil, is the 15, 20% improvement for real? I'm filming things for posterity--and concerned about how things'll look 10 years from now so I do want something that'll look the best on a 6' and (much) larger screen.
If you plan on showing your work in a large format, I would go with 1080 but If you are concerned with future proofing, that is a tossup - I run my 720 stuff on a 9' diagonal projector and it still looks great.
Phil Hover is offline   Reply
