Why would the FS-100 not do 720/24pn or 720/30pn at DVinfo.net
Old April 22nd, 2006, 08:36 AM   #1
I read an article that it would not do these two formats, how sad if this is true. Would it be a software upgrade to fix it.
Paul Brady is offline   Reply With Quote
Old April 22nd, 2006, 09:38 AM   #2
My understanding is that 720pn will not stream over firewire.
David Saraceno is offline   Reply With Quote
Old April 22nd, 2006, 09:43 AM   #3
It's not that it won't stream over Firewire... It's an issue of the DVCPROHD codec, or at least that's the way I understood it. Standard frame rates for 720p DVCPROHD are 30fps and 60fps. Therefore, you can only record 24p over one of those rates via firewire (or to a DVCPROHD deck). If you want 24pn or other native rates besides 30/60, you must record to P2.
- Jeff Kilgroe
- Applied Visual Technologies | DarkScience
- www.darkscience.com
Jeff Kilgroe is offline   Reply With Quote
Old April 22nd, 2006, 09:58 AM   #4
At least until the Cineporter is released, which I understand to mimic a p2 card
Old April 22nd, 2006, 10:05 AM   #5
Yep. That's why the Cineporter connects via a P2 card slot rather than via firewire. It allows recording to HDD the same as you would record to a P2 card. So you get all the frame rate options, proper MXF files and all your metadata.
- Jeff Kilgroe
Old April 22nd, 2006, 10:54 AM   #6
now THIS is whats intriguing...
lets hope the wait doesnt dissapoint...
Peter Jefferson is offline   Reply
