DvcProHD or Dvc50 for Shoot?
Using a rented Hvx, we are shooting a single scene from a feature film script I'm shooting in the fall. We're probably shooting the movie on a Varicam but we can't afford to rent it for just this "demo" scene. Basically, this is to give our investors a feel for how I'm going to direct the flick. The scene will be viewed from a DVD source so I'm wondering if shooting DvcPro50 would be better than shooting in HD mode since it's being viewed on DVD. Would shooting in HD mode offer any distinct advantages? How about DvcPro50?
Thanks! |
having a master at the highest posible quality is the best way to go, especialy for archival purposes and who knows, maybe u can add that to the features DVD as a special feature when ur movie gets released..
in the end though, having the hihgest quality master would give u the headroom to do anything u want with it. |
That is an interesting questions.
Our 720pn footage looks fabulous when taken to DVD. However, I had believed that DVCPro50 has a better chroma sampling that DVCPro100. Could be wrong on this. |
David, are you saying there was less chromatic noise or did you see more detail? In what way did you feel the DvcPro50 had better sampling? I take it you mean the saturation had less distortion/artifacts. Would that be accurate?
#5 |
Shoot HD
Always shoot the highest quality acquisition format possible for the project. It's like saying 'we don't want to shoot 35mm since we are ending up on DVD anyway'. The statement of not shooting HD because you are ending up on NTSC doesn't make sense, especially if you are making a feature film. You want it to be impressive and sell your project, so make it the best it can be.
You will probably see that you will be able to shoot your film on the HVX anyway, and forget the full size Varicam, unless you are trying to impress the crew and/or investors with a big camera. Get the experience shooting HD now if you are going to be shooting the film in HD. |
#6 |
Call me crazy but I heard someone on here (Barry Green maybe) mention something about dvcpo50 outperforming dvcprohd when downrezzed. I'm not a D.P. (I'm a director who hires D.P.s) so I can't imagine why that would be. David already mentioned the dvcpro50 having one advantage from his own tests. I'm curious to hear from others who've conducted similar tests.
#7 |
Hawaiian Shirt Mogul
i believe the 720p files are the same size as the dvcpro 50 files ..so that could be reason that DVCpro 50 outperforms dvcpro 720p when 720 is down rezed??
http://codecs.onerivermedia.com/ click on 4:2:2C |
#8 | |
HD *IS* 16:9 - does NTSC SD on the HVX give a 16:9 option? |
#9 |
Barry Wan Kenobi
Yes SD on the HVX is 16:9 or 4:3, your choice.
If I were shooting for DVD release, I'd shoot DVCPRO50. Same res as the DVD, and much milder compression than HD. The best-looking standard-def is gonna come from shooting DV50. If you have other plans for your footage, originating in high-def makes sense. But if it's only for DVD, I'd say just shoot DV50 in the first place. |
#10 |
Correct me if I'm wrong, but shooting in DVC Pro 50 means no variable frame rates, right? That would be a big selling point to me, but if the shoot doesn't call for it then maybe it doesn't matter.
#11 |
@ Ashley: No, DVCPro 50 stands for the compression rate, twice as 'better' as DV which is 25mb per sec. But the HVX does do variable framerates for slomos in HD.
#12 |
Barry Wan Kenobi
Choosing DVCPRO50 would limit your frame rates to either 24p, 30p or 60i, that's true. You could swap over to HD and shoot the variable frame rate stuff in 720p and downrez... but if you're going to do that, why not shoot the whole thing in 720p and downrez it all, because that way you'd have an HD source to go from...
Good point. If your project needs variable frame rates, probably best to shoot in 720. If you're not going to use the variable frame rates, and it's for DVD only, I'd use DV50. |
#13 |
Wouldn't shooting 1080P and down-sampling produce superior results to DVCPRO50? A proper down-convert should yeild nearly 4:4:4 SD. Not that it matters when you're compressing to 4:2:0 DVD - but still... better out of principle.
-Steve |
#14 |
Barry Wan Kenobi
If that was the only thing at work, maybe. But consider that DV50 is much less compressed to begin with -- 3.3:1 vs. HD's 6.7:1.
Downconverting in-camera to the DV videotape doesn't hold a candle to shooting DV50 in the first place. Downconverting in post yields results that are very comparable -- so why bother? Doesn't make for any better-looking final product, yet it's a lot more work. Well, to each his own, you won't really lose anything by going either way, but if you choose to shoot HD you'll have an HD master if you ever need it. |
