How's the HVX image stabilization?
Can anyone comment on this yet? Is it the exact same system as the DVX, or an improvement? All I can find looking on the internet are standard retail descriptions. It's important for my planned uses, so I'd appreciate any input.
The original dvx OIS was very weak. I believe Barry Green said it was a major improvement over the DVX one, so this should be reasuring.
If you don't believe in your film, no one else will. |
Barry Wan Kenobi
It definitely seems better than the DVX OIS. Especially considering that the lens is some 20% more telephoto. I haven't tried 'em in a side-by-side yet, but just from first impressions I felt that the HVX OIS was more effective than the DVX's was.
Thanks to you both (Sergio, Barry). Yet another reason I'll probably opt for the HVX over a late model DVX.
Barry, any sense of how well the HVX OIS might handle closeups inside a moving car - assuming it's handheld, the car's not going over 45mph, and the road's well paved? I'll probably rent a Steadicam where I need super smooth traveling shots, but I might also just film from a wheelchair with the OIS on if I can get away with it. Mild camera shake does not bother me. In some cases it might even seem obligatory, such as an actor's P.O.V. while being pursued by an angry chihuahua (that's a real scene I have to shoot). Getting a good idea of the OIS's limitations would be very useful if you can impart that so early in the HVX's debut. |
#5 | |
#6 | |
Barry Wan Kenobi
#7 |
I had a quick test of the HVX stabilizer and you could notice the difference with it on, which is a good start. I thought it was about half as effective as the OIS in my trusty Canon XM1 (GL1). I wouldn't want to shoot handheld with a HVX without support, probably a monopod. It seemed to me that the control layout was also aimed more at tripod shooting than handheld. On a tripod, the controls are a joy to use.
#8 | |
#9 |
Anyone have examples of where and when they've used OIS with satisfactory results? If not with the HVX, then preferably with the DVX, since it's looking like the HVX system will be able to match or exceed it. Are there any tricks or pointers for using OIS to maximum effectiveness?
#10 | |
