#46 | |
Go Go Godzilla
Using external power on the card is for those times when you are using a device that actually draws power from the FW bus itself. It's not required if the device has it's own power. |
#47 | |
Thanks Robert. I thought that was the case, but as I said I have a big learning curve ahead of me equipment wise and I appricate the reply. David |
#48 |
Robert or anyone,
When recording directly from HVX to Powerbook via firewire in FCP using capture now : Is there any wat to get the cameras timecode? Every clip I get starts at "O" regardless of the camera settings even with camera at Freerun. If you can't get the cameras timecode, how have you been setting a new or alternate timecode on your clips? |
#49 |
this thread should be a sticky IMHO. Thanks for the info Robert and prehaps you could help me on my other thread.
http://www.dvinfo.net/conf/showthread.php?t=61975 David |
