HVX200 + MPIC 35mm Imager - Page 2 at DVinfo.net
Old February 6th, 2006, 12:35 AM   #16
It's really very interesting to me,
I see the Noise, and in a certain way I have to agree with other forum members who call the HVX a medium/high def camera,
But...
I Don't think I Care
Steev, the footage that has been posted is so beautiful.
I am inclined to agree with you - bring on the noise.
John Benton is offline   Reply With Quote
Old February 6th, 2006, 01:04 AM   #17
Presenting.. The Polar Bear
http://www.holyzoo.com/media/video/H..._Bear_1Mbs.mov
www.holyzoo.com
Steev Dinkins is offline   Reply With Quote
Old February 6th, 2006, 05:51 AM   #18
Hi Steev.
Now that you tried your new LCD with the HVX, what about the difference beetween component and YC? Still necessary?
Alvise
Alvise Tedesco is offline   Reply With Quote
Old February 6th, 2006, 11:35 AM   #19
Steev
HAHAHHAHA You are a funny man. A funny man with a lot of stuffed animals :)
Jesse Rosten is offline   Reply With Quote
Old February 6th, 2006, 06:00 PM   #20
Originally Posted by Alvise Tedesco
Hi Steev. Now that you tried your new LCD with the HVX, what about the difference beetween component and YC? Still necessary?
The Marshall and Component HD in vs S-video. Every once in awhile there are things that I get defiantly adamant about. This is one of them. Component HD input is a MUST! If you have to borrow money, or charge on a credit card, you will not regret this purchase. $1350 at BHphoto - buy and cry once, and know you have it covered.
www.holyzoo.com
Old February 7th, 2006, 01:12 AM   #21
Another 35mm grab - http://www.holyzoo.com/content/hvx20...0_35mm_023.jpg
So I finally got playin around with more HVX200 stock lens shooting.
Sunset timelapse was gorgeous - I should have stayed longer though - http://www.holyzoo.com/content/hvx20...HVX200_012.jpg
Tripod spin on the horizon skyline with zero motion glitch, very smooth:
http://www.holyzoo.com/content/hvx20...HVX200_014.jpg
http://www.holyzoo.com/content/hvx20...HVX200_015.jpg
Some camera-in-car shots while driving. I had the shutter on 1/12th for these, so some nice blurring effects are possible. If I didn't want blur, I just gotta find more light, since I refuse to gain up.
http://www.holyzoo.com/content/hvx20...HVX200_018.jpg
http://www.holyzoo.com/content/hvx20...HVX200_019.jpg
http://www.holyzoo.com/content/hvx20...HVX200_020.jpg
http://www.holyzoo.com/content/hvx20...HVX200_021.jpg
http://www.holyzoo.com/content/hvx20...HVX200_025.jpg
More video clips:
35mm:
http://www.holyzoo.com/content/hvx20...5mm_Test06.mov
Stock Lens:
http://www.holyzoo.com/content/hvx20...ock_Test03.mov
35mm around sunset time (I should have been zoomed in more):
http://www.holyzoo.com/content/hvx20...5mm_Test07.mov
www.holyzoo.com
Old February 7th, 2006, 09:35 AM   #22
Steev, is it just me, but based off your recent HVX200 footage, this camera has the best color rendition I've seen on a sub 10K camera.
Thanks for sharing.
Also, it looks like it's capable of less noise once set correctly for the scene.
Old February 7th, 2006, 09:55 AM   #23
Agreed,
Esp the Sunset Clip -
NOTICE: The Noise disappears in the darkds when there is Higher contrast and you have some part of the frame Well lit/with strong Light !!!
Infact Steev's footage helped push me over the edge with this Camera !
Thanks. Keep it coming !
Cheers,
J
Old February 7th, 2006, 09:56 AM   #24
Steev, thanks for your WONDERFUL clips. They're all jaw-droppers !
My request ;
* Could you post some 1080/24p clip at original 1920x1080 size ? (with MPIC of course)
* Could you stop down the lens to, say f16 or f22 ? (w/MPIC, 1080/24p would be great)
Thanks a lot
Shivuya Konban is offline   Reply With Quote
Old February 7th, 2006, 09:59 AM   #25
Wow, that was my 1st post here.. I didn't realize.
Steev, upon above request, DVCPRO HD QuickTime would be so appreciated !
Old February 7th, 2006, 10:36 AM   #26
Nice tat! http://www.holyzoo.com/content/hvx20...HVX200_026.jpg
So, about 1080, for better or worse, it's not what this cam is all about. This is okay with me, because 720p24N is my preferred mode for the look I want, able to do multiple frame rates, and the efficiency to achieve 40 minutes on two 8GB cards.
Check out these interesting comparisons, all from HVX200 to P2:
DV25
http://www.holyzoo.com/content/hvx20...0_027_DV25.jpg
DVCPRO HD - 720p24N
http://www.holyzoo.com/content/hvx20...27_720p24N.jpg
DVCPRO HD - 1080p24
http://www.holyzoo.com/content/hvx20...27_1080p24.jpg
Now, I'm pretty impressed with DV25 blown up to 1080. It looks even nicer blown up to 720p. Regarding the quality difference between 720 and 1080? It's not enough for me to justify 2.5 times the file size to get 1080. So I won't be shooting any 1080 at all and hence won't be posting those massive raw files either. ;)
Shivuya, and all who may read here, stopping down the lens on a 35mm imager very far is something you should NEVER do. I've tested this a bunch and I've come to the following conclusion. I'll use the 35mm rig for very shallow dof shots only. If I need deeper dof of variable dof, the best I can do is use the stock HVX. This is an important point. The shallow dof on wide open primes on these 35mm rigs will NOT give you every look you want. Many times it's overkill in its mere slivers of areas you can focus on, you can't adjust it very much, and focusing is like performing surgery. I'll be enjoying shooting on the stock lens a whole bunch, and pop in the 35mm for shots that justify it.
*Added note... I didn't mention why. The reason you don't want to stop down these lenses is that you add noise and grain to the image in varying degrees and at f8, f11, or certainly at f16 or farther, it's a wreck, disaster, destruction. So to me, anything that adds undesireable noise and grain to my image, past the initial nice shallow dof and clarity from being wide open, I can't justify the stop down and introduce noise for the sake of increasing dof.
Stay tuned for more eye candy!
www.holyzoo.com
Old February 7th, 2006, 11:09 AM   #27
hmm, hence HVX is called Medium Def camera... 720, pretty good for the price of the cam but 1080, not up to par other camera (H1) does offer ;-(
Originally Posted by Steev Dinkins
stopping down the lens on a 35mm imager very far is something you should NEVER do..... The reason you don't want to stop down these lenses is that you add noise and grain to the image in varying degrees and at f8, f11, or certainly at f16 or farther, it's a wreck, disaster, destruction.
That's bad. I imagined or hoped Dan's MPIC (or G35 VIBE version) could let us do that ! I always wanted the choice to open / close the iris for DOF aesthetics... so the real solution to this would be the RED camera then.
Old February 7th, 2006, 12:13 PM   #28
720p is HD. Don't freak out. And if you are just trying to win a resolution race, go buy the Canon.
Yes, go raise $200k and buy the Red camera. Or go shoot film for that matter. This is indie stuff here. Sounds like you are hard to please in general, so good luck man. Sour grapes or a god send? I'm still blown away by what's possible.
www.holyzoo.com
Old February 7th, 2006, 01:05 PM   #29
Yes, go raise $200k and buy the Red camera. Or go shoot film for christ's sake. This is indie stuff here. Sounds like you are hard to please in general, so good luck man. Sour grapes or a god send?
All right, now, let's keep it civil. He was just giving feedback, let's not bring Jesus into this just yet:)
And the 1080 freeze frame of the blue box with stars looked good to me:)
Betsy Moore is offline   Reply With Quote
Old February 7th, 2006, 01:43 PM   #30
:) Yes yes. Jesus can wait a little longer.
*News Flash* I just spoke to Brian at RedRock and he set me straight on controlling dof. It appears that the M2 can handle smaller apertures without artifacting. Who knew? Well the guys at Red Rock knew. Very intriguing, aint it?
www.holyzoo.com
