#46 | |
- Jeff Kilgroe - Applied Visual Technologies | DarkScience - www.darkscience.com |
#47 | |
Panasonic Broadcast
Please asnswer asap, I have a call into my guy at Avid. Thanks, Jan
Jan Crittenden Livingston Panasonic Solutions Company, Product Manager for 3D and Handheld Cameras |
#48 | |
HDV Cinema
OT -- colored ...
I bought a hot PC last year because of all the options for HDV support. Now it looks like I'll need to upgrade my Mac because of FCP and its DVCPRO codecs. I'm not sure these are only temp issues -- all to be solved by NAB 2006. I'm afraid we are going to see an increase in the use of "alliences" to levergage mutual sales. I to have to buy a Sony deck to play 1080i "HDV" and a BR to view Sony movies, while having to buy a JVC deck for 720p "HDV," and a Toshiba HD DVD to view a TW movie. (OT2: TWC just turned-off the ability to record HD on JVC D-VHS decks via FW.) If I buy an hp computer will it be able to play an HDCAM or BR disc? If I buy a hot Apple Intel iBook, where do I plug in a P2 card? Lastly, the new iPod drops Firewire in favor of Intel's USB. I don't know how a small post house -- or consumers -- can deal with this level of deliberate fragmentation. Will we all need 2 kinds of HD DVD burners? Lastly, lest we forget, Panasonic has publically (NAB 2004) announced that they will release MPEG-2 based, low-cost HD camcorders -- which makes far, far more sense for P2. All they need is a low-power 720p60/1080i MPRG-2 encoder. (It wasn't ready, so they switched, at NAB 2005, plans and went with DVCPRO HD.) So by the time DVCPRO HD is fully supported -- end of 2006? -- we may only be months away from a whole new line P2 HD products that will be significantly more media efficient. And, a whole new cycle of NLE non-support. Happy New Year!
Switcher's Quick Guide to the Avid Media Composer >>> http://home.mindspring.com/~d-v-c Last edited by Steve Mullen; January 3rd, 2006 at 01:02 PM. |
#49 | |
Note: http://www.infoworld.com/article/06/...yawards_1.html 2006 Technology Awards "Best Client Operating System Mac OS X v10.4 Tiger A rich and friendly desktop OS built with professional users in mind" |
#50 | |
I'm only basing all this off the limited amount of footage available right now. I don't own Avid, but have been investigating Xpress Pro HD as a possible platform to migrate to as I currently use Vegas. I have spent some time over the past week with a local dealer, trying various NLE systems with the limited amount of HVX200 clips that are available online. What I have found with Avid (and this seems to be confirmed by other Avid users here and on dvxuser.com) is the following: 1. Can not get a 720pn clip shot at 12fps to import. I don't have the exact error message in front of me, but it was essentially an unsupported framerate or unsupported data rate type message. This clip will also not load into DV Film Maker, which according to Barry Green, does support all the various frame rates. There may be a problem with this MXF file. 2. DVCPROHD @ 1080 does not import at all intoXpress Pro if it's wrapped as an Apple QT (this is may be a QT compatibility issue, 720p QT works fine). If being imported from the native MXF, Avid wants to insist that it's Sony's MXF for XDCAM and not DVCPROHD. It took some fiddling around and one of the guys at the local shop I'm working with finally got the 1080i clip to load - I think he had to manually remove codec support from the system and essentially eliminate anything related to Sony MXF and/or XDCAM. Another system had the same issue and I've seen at least one other user on dvxuser.com report the same issue. Once the clips are loaded into Avid (720 or 1080), the performance is absolutely horrid! On a dual-core PentiumD (3.2GHz, I believe) with 2GB RAM and 4x320GB SATA-II drives in a RAID-0 config, we were only able to run 4 ~ 5 frames/sec with a single stream. Converting to Avid's QNxHD allowed us to run multiple streams simultaneously. Avid obviously needs to do some serious work with their DV100 codec. Results were the same on a secondary edit system and others have reported the same performance issues.
#51 | |
Apple OSX - it's BSD - it's friendly. It's easy enough for novice computer users to actually be productive with and it still lets most advanced users dig into the inner workings of their system. But with the simplicity does come trade-offs. If I want the ultimate in control and flexibility to hook up with any sort of network, I'll still take Windows or Linux over OSX. Right tool for the job, ya know. Besides, we all know that PCs are thw whores of the computer world -- they'll hook up with anything.
#52 | |
Skyonic New York
well for one thing edius does support 1080/30p so i wonder what version of edius you were using... as for varicam available framerates you can shoot at any rate you want, but the end result will always be 60 frames every second, the varicam shoots to tape...as for the hvx the only times it writes true frames is in 720p mode 24pn/30pn, which Edius offers... what version of edius where you using??? |
#53 | |
I'm aware the Varicam shoots to tape and that all its rates are transferred over 60p. I thought I addressed that in my original post - oh, well. That's beside the point. My comment on Edius and support for these frame rates is that we're limited to working in rates that Edius supports as standard. Sure, we can shoot 48fps over 60p and that's great if I want that effect on a 60p timeline... But what if I want to shoot 18pn and edit in 18pn and deliver in 18pn? Sounds weird, I know, but I actually have an application for this if I can do it. Avid (somewhat), FCP, Vegas (alas no DVCPRO support) all let me work with frame rates the way I want or very close to it, Edius doesn't directly -- too many work arounds and extra steps/conversions to get there. If I'm editing only for broadcast or DVD distribution, then I guess it wouldn't be bad, but I'm buying the HVX200 so I can make serious use of the frame rate options for effects work and reference for animation and I can think of situations where I would want to author a 36 or 48 or 12 or 18 fps reference file for use on other workstations. Granted this is all relatively new territory for a lot of NLE systems and it will take time for it to mature. But when my HVX arrives, I will go to whichever system gives me the most abilities to do what I ultimately want to do.
#54 | |
Skyonic New York
hvx is only 24pn/30pn no matter what frame rate you choose in pro3.61 to get the 1080p mode just go to project settings/ framerate -> all frame size - > hd edius is not the best nle far from it, but it has the best implementation of dvcpro hd and Canopus has not dropped the ball when it came to that... |
#55 | |||
#56 |
Skyonic New York
i started using edius since version one to cut our daily interviews, it works great and has come along way, and one day it may be our sole editor again, but as for right now fcp looks like a winner even with the clumsy mxf suport...
even staying with vegas makes sense, good luck |
#57 | |
Barry Wan Kenobi
