#61 |
FWIW, George Lucas shot SWII, III almost exclusively with DTE drive arrays and used them for a limited shot selection on Episode I. ;-P
But in all seriousness, I do agree these are things to be concerned about. Those shooting LIVE EVENTS will have the most to be concerned about. Studio setups are really not that concerning (and I'm pretty much a studio workflow guy). I do a lot of shooting in the outdoors, some scenary and wildlife, but this is for my own use as stock footage. If the hard drive craps out when doing this, I may be disappointed, but nothing critical is lost. The other crowd who may have some concerns is the ENG people. For ENG, it makes the most sense to have 2 or 3 P2 cards with the P2 store clipped to your belt. But you never know what could happen. IMO, the P2 Store looks very solidly built and I wouldn't stress over it too much as long as you take care of your gear (and hope your employees do the same). Overall, I've had very good luck with hard drive reliability. I won't say that I've never had one fail. But it's not something that I stress over on a daily basis. Yes, I would be nervous about an HDD recording unit failing in the middle of shooting a concert or live performance type event. I probably would refuse to shoot with anything less than a RAID-5 array, preferably two of them mirrored. Then I wouldn't think anything of it, probably less of a concern than P2. As for DTE record solutions for the HVX200, Firestore makes me nervous. It seems overpriced and we're putting a lot of faith into a single 100GB 2.5" HDD running at 7200rpm. The CinePorter seems like a better solution as it connects to a P2 slot and will have all the metadata in addition to the A/V stream and timecode. Word has it that the Cineporter will hold 2 x 2.5" drives. Sure, with current capacities that would give us 220~240GB. But how about a 160GB record drive with a second mirror HDD? I suppose it would also be possible to record to both the CinePorter and a Firestore simultaneously. If one fails, the other should still be OK. This also brings up a question I have been wondering... Can the HVX200 record the same thing to two P2 cards simultaneously? Seems like a no-brainer and no real technical reason it couldn't, but did Panny think of implementing this feature? May be helpful to record to two CinePorters at a time or if nothing else, it would facilitate future situations where P2 cards are cheap and you shoot one for yourself and the second can be instantly handed off to a producer or client.
- Jeff Kilgroe - Applied Visual Technologies | DarkScience - www.darkscience.com |
#62 | ||
Actually, I run RAID0 on a few minor systems and my gaming rig at home, etc.. But for a production environment, it's pretty trivial and not all that expensive to add the third HDD and run RAID-5. If you have a 4-drive config in RAID-0, add just one more and reconfigure. Quote:
I have mine on order thru EVS as well... I'm probably somewhere at the bottom of the list, which is fine with me. As for the XLH1, I would have already bought one if it had the frame rate options of the HVX and didn't build 24F mode from an interlace scan. Although, I still may pick one up as I do run a 2 camera workflow and I'm planning to start by replacing my B camera (a DVX100) with my DVX100A and making the HVX my primary. If all goes well, I'll be replacing the 100A with either another HVX or an H1. Which I will probably have to do anyway to keep everything in HD.
#63 | |
#64 |
Hmm, after reading all these posts, you all have convinced me of one thing,
I should hold out for the upcoming XDCAM HD which will give me the best of both tape and Disk recording on a nearly indestructible Mini Blue Ray disk. You can use the camera as an external removable media device for your NLE via firewire if you want to. Tapeless, yet better than tape or magnetic disk. Thanks folks, thanks a lot, now I have convince my better half why the budget went from 10k to over 20K. Just to save you from her wrath, I won't tell her I got help from DVINFO. (just kidding folks, almost). |
#65 |
The bottom line....
Tape is on it's way out. There's no question about it. I stated I want a tape after production is over, but in reality...I would in fact prefer to be tapeless. Anybody who thinks otherwise is just blind.
Just like 8-track, just like VHS, just like Cassette Tapes, and now...CD's. In fact, you couldn't PAY ME to buy a DAT recorder for field recording today. Compact Flash all the way! When I slow down and think of that silly statement I made about prefering a Tape after production.....Well, my only Gripe, and the reason "I prefer Tape" today, is the price of P2. See the reason why you couldn't PAY me to buy a Fostex PD-4 DAT player today, is because the Fostex FR-2 takes a Compact Flash Card. Quiet, Clean, Fast and Just as good! The CF Cards is someting I can get at Circuit City or eBay for a few bucks. If HD or HDV cameras were able to accept MicroDrives or 8GB Compact Flash cards, and I were able to buy them on eBay as readily as I can now then I would drop MiniDV tape in a HEARTBEAT! But that's not the case. MOREOVER, if HD or HDV cameras were able to record directly to 2.5mm laptop drives directly....I would say "GOODBYE MINIDV, HELLOW LAPTOP DRIVES" Alas, that's not the case. P2 Cards are proprietary and expensive and hard to find and usable for one thing and one thing only. (unlike laptop drives and CF cards). So I guess that's the issue. But yes. TAPE IS ON ITS WAY OUT.....FLASH MEMORY IS ON ITS WAY IN, and it's a better way of working in ALL workflows. There's no arguing that fact. And anybody who owns a digital camera and takes it on those special one-time-only vacation, honeymoon, wedding moments should not say otherwise. WHEN...is the only argument. and personally, I don't even like the XDCAM discs. FLASH MEMORY is what these companies should be concentrating on. Sony should be trying to figure out a "SUPER MEMORY STICK" or a way of implementing a CF card rather then pouring into XDCAM discs. The xdcam recording format is fine, the recording medium is not. - ShannonRawls.com
Shannon W. Rawls ~ Motion Picture Producer & huge advocate of Digital Acquisition. |
#66 | |
#67 | |
Barry Wan Kenobi
#68 | |||
Barry Wan Kenobi
Regarding the CinePorter's dual-drive capability, presumably they'll build in a mirrored RAID potential for those who want additional protection. That could be a big advantage for those concerned about ultimate reliability. Quote:
#69 | |
Barry Wan Kenobi
Now, with that said, what I'm hoping to see is a CF-to-P2 adapter. I'd love to see something developed that lets you plug in an off-the-shelf CF card and record straight to it. The problem is the speed of the cards -- the only card fast enough for full-bandwidth HD recording is the Extreme III. But for 720/24p, or for DV50, you should be able to get along fine with an Ultra II. I'll ask Spec-Comm to consider developing such an adapter. With their CinePorter they've already reverse-engineered the P2 card slot and all the associated LSI functions; it would seem reasonable that making a CF adapter wouldn't be that much work for them, yet it would be a delightful addition to the recording options! |
#70 | ||
#71 | |
#72 |
Tape may be on the way out but it will not be replaced by HDD. Too many moving parts IMHO. We are a ways off from reliable solid-state (be it flash or burnable) media that is large enough to make tape obsolete. If you have a tapeless workflow I hope you are backing stuff up to DLT or at a minimum a mirror or Raid5.
Even then HDDs fail, check out the testimonials from GIANT projects with redundant back-ups that were recovered over at drivesavers. I agree that, like audio, video will move tapeless but it wont be as fast as you think. Remember, almost every single TAPELESS recording studio backs up all their data EVERY NIGHT... to tape... ash =o) |
#73 | |
Or did you mean compression artifacts? The difference between vcd/dvd and hdv is that priors are used for distribution and the latter for acquisition. It wouldn't look so good if you'd take that vcd made from db and used that as a post production original. And I think the biggest problem with these "barely acceptable quality" solutions (like digital broadcasting many times is with demanding material) is that they limit the artistic expression. You can't use noise or grain to make certain look, because it will get blurred at some point of the chain. Or shaky handheld. Or special shutter speeds. Etc. Well, actually compression artifacts can also be exploited in artistic way... ;-) |
#74 | |
How fast the movement is in the "prosumer" market vs the "pro" market depends on the price of burners and media. Write and copy times will have impact too. Even if 50GB BluRay is only 2x that makes redundancy back up faster than cloning a digital video tape. The one advantage tape has is if there's damage one can work around it to retrieve the rest of the material. Retrieving a corrupted file or data from a physically damaged disc may be near impractical. Probably something closer to a practical "field" workflow would be recording to 16GB P2 cards and then backing up to a portable self powered (battery) BluRay recorder at 2x or 4x speed. Otherwise it might be something like an XDCAM like camera attachment . . . all the more reason to believe Sony will make a 1/3" XDCAMHD camera if the HVX proves popular . . . and another reason why I don't think the HDV format will be around more than a few years as a "dominant" prosumer format. |
#75 | |
You could also make a comparison here to film versus digital options for photography. If you do a lot of photography, today's digital solutions can quickly pay for themselves and the cost of new digital cameras compared to the cost of shooting film. The same may hold true for film versus the alternatives for video, but we're talking about videotape versus tapeless video recording. In several years of shooting video the cost of the tapes I've used would pay for (at best) a few hours of DTE recording capacity, which might just barely match the cost of tapes I'd use in the next few years. And that same amount of money would only buy a few minutes of P2 memory card recording capacity, so that's not even close to being a cost-effective option. As far as wokflow is concerned, one thing tapeless solutions have going for them is that they give you instant access to your data for editing, something you can't get from tape. But if that's not a vital concern, today's tapeless options don't necessarily offer much workflow benefit compared to tape-based recording. In this discussion we've seen it suggested to record video on tapeless solutions and then archive the resulting data to DLT tape -- which is essentially just the opposite process of recording to tape and then bulk-capturing that to a computer hard drive. Maybe not quite the same in terms of time requirements, but not substantially different either. I suppose if you're still batch-capturing your footage from tape by reviewing each clip first then tapeless solutions would look appealing, but that just shows how out of date the batch-capture process is. So it's not tape-based recording which is on its way out here, it's batch capturing. Tape-based recording will be around for at least another five years or more, until some really cheap and effective alternative becomes commonplace. |
