Thread Tools
Search this Thread
#16 | |
Re: Ag-hpx600
And also 128gb P2 cards to compensate for the halved recording times.... |
#17 |
Re: Ag-hpx600
Well yes - but what I was really referring to was slo-mo shooting - shoot at 60fps for 24 fps playback. AFAIK that is not possible with the 3100? (As is no 720p mode at all?) Yes, true 1080p/60 as a mode would be fantastic - but bear in mind it would require an acquisition format that at I don't believe is currently defined.
Failing the above, at least let's see the possibility of true 1080 resolution normal shooting, and 60/24 slo-mo 720 - as cameras such as the Sony PMW500 do. |
#18 | ||
Re: Ag-hpx600
And I'm not sure about acquisition format either, but with something as new and not clearly defined as AVC-U, there is no reason to think it can't be done given the inclusion of formats with a much higher bandwidth usage. |
#19 | ||
Re: Ag-hpx600
The other point is that S&Q is not simply tied to 60fps/2.5x slo-mo. You may wish just a slight slowing down, and it's quite possible to shoot at (say) 40fps but still end up with the standard 24fps file for replay. Quote:
On a new camera, I'd like to see both, and I'd like to see the varispeed work at full 1080 resolution. |
#20 | |
Re: Ag-hpx600
24p actually has an 80mbps bit rate, and if we had an AVC-I 100 cam that shot 1080 60p, it's effective bit rate would be 200mbps. At 100mbps the codec is simply set to give each frame roughly 500kb worth of data. |
#21 | |
Re: Ag-hpx600
Likewise, interframe compression makes even more sense (at least for acquisition) the higher the framerate - a codec can take advantage of the correspondingly smaller differences frame to frame. It's likely that the time interval between I-frames will remain the same - hence doubling the frame rate will mean doubling the number of difference frames between I-frames. This is why for AVC-HD 28Mbs peak for 1080p/50 is seen as roughly comparable quality to 24Mbs for 25p. Doubling the frame rate shouldn't mean doubling the bitrate. |
#22 |
Re: Ag-hpx600
Perhaps not, but AVC-U is currently known to allow up to 200mbps bit rates, which could be used as an excuse for adding that capability.
#23 |
Re: Ag-hpx600
<<A little off topic, but it seems the 600 is basically a 3100 with CMOS, and future upgrade that will allow you to shoot long-gop in addition to intra. Besides the obvious CMOS vs CCD thing, the 600 is only $4000 cheaper body only.>>>
There's quite a quality jump between HPX-600 and HPX3100. The 3100 has all of the fine color matrix and corrections w/ Film Rec gamma. It looks like real high end broadcast when a decent $28-35K real HD lens is placed on it. HPX600 seems to be just like the HPX500 but w/ updated chips. Colors are just not as pristine somehow w/ the HPX-600. Panasonic is very careful of keeping the camera's costs and performance in reality check. For example: Most people think that buying the HPX-370 will replace all of their HPX2000, HPX3000 series. They were in for a big surprise. It performed dismally when lighting is not ideal. In real life, lighting is never ideal. So that one example where the more $$ is spent on the camera, the better the quality. |
#24 | |
Re: Ag-hpx600
Yet the PMW350 is (as expected) 2/3" 3 chip - the HPX600 is only single chip, with the quality compromises that makes inevitable. Use a single 1920x1080 chip and that will inevitably decrease the colour resolution and bring the colour aliases well in-band (below 1000lpph) - that's why you're seeing "Colors are just not as pristine somehow." Last edited by David Heath; January 7th, 2013 at 04:23 PM. |
#25 |
Re: Ag-hpx600
That explains why it's so muddy looking on the HPX-600. With the exact same lens, I swapped to the HPX-3100 and 3700. Considerable difference in quality. You can instantly see the 3000 series cameras are taking full advantage of high end 2/3" lens w/ colors are popping out on every areas on the frame. And there's no CAC turned on yet. Can't really compare the two as they're different classes of cameras (Single MOS vs/ expensive 3-CCDs). The HPX-600 is definitely tailored to a different market than the 3000 series.
I recall many years ago exact same issue with the HPX-500 and HDX-900. With the exact same 2/3" lens, somehow the HDX-900 footage looked much richer with all of the nuances vs. a flat look on the HPX500. And unfortunately either HPX-500, HPX-600 have 12 pole, 14-bit color matrix adjustment. Just simple presets with limited parameters found on the HPX250, 370. >> Yet the PMW350 is (as expected) 2/3" 3 chip - the HPX600 is only single chip, with the quality compromises that makes inevitable. Use a single 1920x1080 chip and that will inevitably decrease the colour resolution and bring the colour aliases well in-band (below 1000lpph) - that's why you're seeing "Colors are just not as pristine somehow."<< |
#26 |
FOR SALE: PANASONIC HPX600 / Fujinon XA17X7.6 BERM...
I have one AGHPX600 with color viewfinder and Fujinon XA17X7.6 BERM M6D lens that I purchased new in May, 2014 and now need to sell ASAP. I'd be interested in selling the body or lens separately as well. If you are, or know anyone who might be interested please let me know...it will be a great deal since there is under 150 hours on the camera. Todd Simon THS-Visuals 775-588-6976 todds@thsvisuals.com |
#27 |
Re: Ag-hpx600
Just had the unpleasant experience of owning an HPX600 with XA17x7.6BERM lens for a couple of days. It is without a doubt the worst camera i have ever owned. The video sharpness was on par with my old SPX800, soft, muddy, absolutely no resolution. 1080p in AVC100 looked just as bad as 720p in AVC50, both looked SD. And forget about using SD lenses on it, the single chip sensor will not work with them, you will get unimaginable left side blurring due to CA. Also, the HPX600 is NOT an f12@2000 camera, it is an f9@2000 camera, and to get that f12 you must switch to low light mode which adds a base 6db of gain under the 0db setting. Factor in it being 59db s/n at f9, and you are looking at the equivalent of 9db of gain noise on an actual f12 Sony PMW350. And not to be left out, the HPX600 has absolutely no detail or matrix menu adjustments. Your vectorscope image and colors look like an octopus having a seizure.....nothing you can do about it, you are stuck with colors that are simply wrong. And crank all three of the detail adjustments up and down, well, they have no effect on the image. Engage 4x digital extender and focus magnifier, and no change in edges will be seen. Highlight colors are also severely washed out, meaning something such as red or blue police LED's in news will not only be the wrong color hue, but not have any saturation at all.
All in all, the worst camera I have ever owned or operated, and my station issues me a JVC HM790. The only good thing is you can shoot everything at night on 0db in low light mode. Then again, I could do that on my SPX800 with full matrix adjustments and a $1000 22x SD lens. Not much has been made clear on this model in the several years it has been out, but I wanted to warn anyone who might be unlucky enough to want one to think twice. Paul |
