#16 |
Re: New for NAB
The AF-100 does NOT use the GH2 chip, and Jan Crittenden has stated that numerous times.
#17 | |
Re: New for NAB
#18 | |||
Re: New for NAB
A few posts back she corrects me, and says: Quote:
There seems to be pretty good evidence from Phillip Blooms Xmas shootout - http://www.dvinfo.net/forum/new-cano...ml#post1706302 . He shoots on the same lens, same view, from same position with both the AF100 (10min 18sec) and the GH2 (13min 40sec) - and it's obvious the GH2 does indeed have a noticeably wider angle of view. (I'm not prepared to draw any other conclusions from that test - the lighting has changed for one thing.) The explanation provided to me said "It's easy enough to prove all the above if you have a GH2 and AF100. Put then side by side and shoot video with them locked off with the same lens. You will find the angle of view of the GH2 to be a bit wider than that of the AF100, the above theory predicting about 8% wider." I tried to quantify the difference between the images in Philip Blooms examples and I made it to be approximately 6-7% - a pretty good correlation with the 8% that was predicted, given the margins for error. I'd be interested if anybody is able to redo the comparison under more controlled conditions. Quote:
It still won't compete with all the "designed for video" sensors by a long way, but would be an improvement. At least it would mean the quality would be on a par with the GH2. |
#19 |
Re: New for NAB
Here's an idea I just had: a 4K 2/3" camcorder!
This sounds outrageous at first, but this should be quite doable, considering that with modern advances in sensor design (gapless micro-lenses) it would have about the same pixel pitch as a 1/3" camcorder... when Canon released the the 1D4 a while back, it was claimed as having a higher resolution over it's predecessor (16mp vs. 10mp), but with the exact same pixel size on a same-sized sensor. There aren't many 2/3" lenses that could provide the sharpness needed to make use of 4K, but the extra resolution can allow for over-sampling to 2K/HD until optics catch up. Edit: while I'm on a roll, would it kill to also ask for some sort of log/linear gamma? I know there's more DR available in these cameras than the software allows for. Low-contrast settings (Cinelike D, low knee, master ped 0 etc.) look like what you'd get from a stills camera with the contrast turned up to 11. |
#20 | |
Re: New for NAB
This two things are a lot more important to me than 50 more lines of resolution. I'm sure that I'm not the only one in this matter. Anyway, there must be a reason why AF100 uses a lesser amount of the chip area than the GH2... |
#21 | |
Space Hipster
Re: New for NAB
#22 |
Re: New for NAB
#23 | |||
Re: New for NAB
Hence each photosite must be only about one tenth the area (very approximately) to that on the F3/FS100 - is it really a surprise that highlight handling is not as good as the "designed for video" sensors? Quote:
So the 648 of the AF100 is still a significant improvement over the 612 it would have been initially. (And if anybody does still have any doubts, these calculations show that it definately does have the GH2 chip, it wouldn't be able to get to 648 lines with the GH1 sensor, with the processing used.) |
#24 | |||
Re: New for NAB
Off course, ditching P2 and going the CF road or even SDXC as you suggested would be an general improvement. P2 is to expensive to be in this lower end market segment! It's that simple. Remove it. But as we've been through this legacy issues I won't go through them again. Quote:
It's funny that all this time we thought that the AF100 uses the GH2 chip!:) There's actually a lot of people walking around wishing that Panasonic would introduce a revised AF100 camera at NAB this year that would feature the GH2 chip!:) |
#25 | ||||
Re: New for NAB
#26 | |
Space Hipster
Re: New for NAB
I honestly liked the original design of the Scarlet better than what it is now. Mainly, the $6,000 target price. I'd have been very happy with a 2/3" chip, fixed lens and 4K resolution. I'm waiting for the eventual reviews of the forthcoming HMQ10 to see how close JVC comes to the original Scarlet concept. I work with EX3s all the time, and I don't feel crippled with the 1/2" chip size. But I'll admit, my FS100 has spoiled me with its Super-35 sensor. |
#27 | ||||
Re: New for NAB
And the economics are such that even two C300 parallel recordings still work out much cheaper/minute than a single one on P2! Quote:
This is one of the reasons why using a sensor primarily designed for stills is highly unlikely to give as good results as one primarily designed for video. And going for four/thirds (approx half the area of s35) exacerbates the problem. Quote:
As far as "typical camcorders", then with the EX as an example, it's sensors are each about 1/8 the size of a four/thirds sensor - but it has about 2.2 megapixels each compared to the 18 of the AF100. As 2.2x8=17.6, I'd therefore expect the EX photosites to be (if anything) a bit larger than those of the AF100. Photosite size may not be the only factor regarding DR - but it's a big one. |
#28 | ||
Re: New for NAB
3x P2 costs $1905 at B&H (SxS is a bit more) and 3x CF cards (Sandisk EP 64GB) is $1,110... ok an $800 difference? I know there are cheaper CF cards, but I probably wouldn't want to use those for anything worthwhile. Considering the useful life of the product, and the likelihood it'll buy itself back, $800 is moot by any standards. Any camera sporting P2 isn't likely to be used by penny-pinching hobbyists. Quote:
If Red isn't using some secret sauce in their cameras, then I don't know what it is. The RED camera has been tested and proven to have the exact same DR as the Alexa, if they didn't label the step chart I couldn't tell which was which. |
#29 | |||
Re: New for NAB
The point I'm making is that I'd rather spend that $1,350 on a better camera - not more expensive memory. If I've got $6,000 to spend, I'd rather it be a $5,500 camera and $500 of memory than a $4,000 camera and $2,000 of memory. This is especially true if you compare something like the HPX250 with the XF305. In many ways comparable, but the 250 is considerably cheaper - until you factor in memory cost when they become similar in price. But the XF305 is better in respects such as the true manual lens (the 250 is servo for iris and focus) Quote:
As far as this discussion goes, then most of the competition to the AF100 are s35 - not four/thirds - and that gives them an advantage to start with. (Twice as big photosites for the same count per chip.) It doesn't surprise me that Panasonic used the GH2 chip in their first camera for reasons of speed and economies of scale, but if they are going to seriously compete from now on, they are going to have to come out with a designed for video chip. And the really big question will be whether it's s35 or four/thirds. Go for s35 and it's all change for lenses, everything. Stay with four/thirds and it will always struggle against all the s35 rivals in so many ways, always be a runner up. It's a tough decision. And the news of the FS700 has ratcheted up the stakes considerably. |
#30 | |
Re: New for NAB
A slightly updated AF100 won't do much now. They must come out with a brand new S35 camcorder! Have you seen the new Sony PDW 680 ENG type camcorder? What are they doing at Panasonic? |
