HPX 370 Audio at DVinfo.net
Old January 11th, 2011, 10:34 AM   #1
HPX 370 Audio
Hi All
I'm sure I am missing something simple but I just want to plug in 1 mic and get a mono signal on both channels 1 and 2 so I can have 2 different levels to chose from in the edit.
Paul San Filippo is offline   Reply With Quote
Old January 11th, 2011, 12:30 PM   #2
Paul,
If you don't have a splitter or Y cord for your mic you probably have to use the front Cam Mic input as the Rear inputs are separate.
Old January 11th, 2011, 01:30 PM   #3
hpx audio
thanks thought so..
Old January 12th, 2011, 06:14 AM   #4
Yes if you use the front cam mic input and then matrix it to ch 1+2 you can do this.
Gary Nattrass is offline   Reply
