Frame grabs from the P2 files? at DVinfo.net
Old October 1st, 2010, 03:06 PM   #1
Does anyone have a simple way to grab picture frames from P2 files?
I do not have any editing for the P2 files (only the Panasonic viewer) so I'd need a software player that will let me pause and save to a bitmap or something similar. Just want to add some pics to my website is all.
"the difference between an amateur photographer and a professional is the amateur shows you all his pictures"
George Odell is offline   Reply With Quote
Old October 2nd, 2010, 11:35 AM   #2
Hi George,
the fastest, simplest and easiest way to do this is within the P2CMS software tool from panasonic, I suppose this is the viewer you're referring to in your post? First select a clip, play it in the viewer, navigate to the right spot and then look for the little blue crosshair on the bottom of the window (see the example i attached) click it and then save it to your disk. Remember that the size of the viewer will actually determine the size of your still. A little desktop 'real estate' wouldn't hurt, especially when you're shooting (and grabbing) Full HD.
Good Luck
John
Frame grabs from the P2 files?-p2cms-.jpg   Frame grabs from the P2 files?-p2cms-b.jpg
John Twigt
http://www.workstation.nl
John Twigt is offline   Reply With Quote
Old October 4th, 2010, 09:04 AM   #3
Thanks John!
I do not have the P2CMS software tool you speak of but I will look for it and give it a try.
George
Old October 5th, 2010, 03:03 AM   #4
You're welcome, you can find the software here: https://eww.pavc.panasonic.co.jp/pro...e/download.htm
John Twigt
