Variable frame rates? at DVinfo.net
Old July 27th, 2005, 08:48 AM   #1
Did I misread the brochure, or did it state the hvx200 will have variable frame rate similar to the Varicam (3 to 24, 60p down to 24...)?
Joe Carney is offline   Reply With Quote
Old July 27th, 2005, 09:11 AM   #2
Hi Joe,
You didn't misread it, the HVX200 will have variable frame rates. What exactly those are going to be has not yet been locked down at this time, but Jan C. (the product manager) told me she was lobbying for 4, 23, 24, 25, 48 and 60 fps.
Old July 27th, 2005, 09:42 AM   #3
23...? what's that all about?
Charles Papert
www.charlespapert.com
Old July 27th, 2005, 10:04 AM   #4
Can't exactly remember, I'm kinda distracted at the moment, but that's what I had in the notes I took during Jan's seminar at DV Expo East last week.
Old July 27th, 2005, 11:48 AM   #5
I'm hoping there's one or two between 4 and 24 and that you can smoothly ramp from 4 up to 60... of course, nevering having used a Varicam, I have no idea if you can do that with the Varicam... But that's what I'd like to see...
Kevin Dooley
Media Director, Pantego Bible Church
Kevin Dooley is offline   Reply With Quote
Old July 27th, 2005, 12:08 PM   #6
Barry Wan Kenobi
There will definitely be variable frame rates, although exactly which frame rates will be included is a detail that hasn't been announced. We're pretty sure it's not going to be every frame rate, as Jan already said on another forum that ramping is a feature that won't really be possible since it won't have *every* frame rate between 4 and 60.
23 and 22 would be quite useful for Hong Kong kung-fu style action moves, where you want the action to be just a little faster than normal, etc...
Old July 28th, 2005, 08:49 AM   #7
Barry,
I can't remember the company, but at HDEXPO last year a guy had a remote that he plugged into the Varicam and he was able to do some ramping, etc., if I remember right.
I had the guys card (the company who was marketing this) but in my move who knows which box its in.
But do you think this could be possible with the HVX?
Gary
Gary McClurg is offline   Reply With Quote
Old July 28th, 2005, 08:58 AM   #8
Skyonic New York
varicam basically has a dial that has no pre set frame rates turn the dial up it goes higher turn it down it goes lower, if what you guys are saying is true i would say that statement is misleading, it should say the hvx has multiple frame rates, pre-set rates are by no means variable...
Robert Mann Z. is offline   Reply With Quote
Old August 23rd, 2005, 03:27 AM   #9
what I want to know is how the HVX achieves this.
The Varicam shoots on variable rates and then goes to a 'processor box' to convert all that info back into another DVCpro HD tape, am I right ?
Since the HVX does not use a tape transport for HD shooting, how is the variable frame rate info going to be processed , straight into a DVCpro HD enalbe NLE on p2 cards ??
Very very curious.
Do more, learn more
Wesley Wong is offline   Reply With Quote
Old August 23rd, 2005, 05:39 AM   #10
Barry Wan Kenobi
The HVX will record exactly the frames necessary onto a file on the P2 card. So if you choose 24fps, it will make a file that has 24 frames per second in it. If you choose 60fps, the same file will have 60 frames in it (and, obviously, it will take up 2.5 times as much space on the card as the same file would have if it'd been shot at 24fps).
If you wanted to shoot at 4fps, you could get two hours of recording on an 8gb card. At 60fps, you get 8 minutes.
But in all cases with 720p, there's no "pulldown", no "duplicate frames" or anything like that -- it stores exactly the frames it needs, and nothing else.
Old August 23rd, 2005, 09:19 AM   #11
At NAB this year, Jan C. gave an invitation-only Q&A session after hours in the Panasonic booth. As she kept rattling off the features, it became more and more apparent that this camera was a handycam version of a Varicam, plus some. The audience kept ferreting out every small difference between the two cameras. Jan was a great sport, and seemed to be answering each question as honestly as she could: "Yes, No, or We don't know-yet". She confirmed multiple frame rates at that time, but when pressed on smoothly-variable frame rates ala the Varicam, she seemed highly skeptical. Here's the quote: "Let's call that a $60,000 feature for the Varicam".
I think it's a lock we'll get 23.97, 24 and 60, as well as a few ultra-slo speeds in the 1-12fps range. I really wonder what the deal is with 48? is it just a simple, round number to hit for 50% slo-mo, easy to implement in the electronics, or is there more to it? The newly released digital cinema specifications include 4Kp 24, 2Kp 24 AND 2Kp 48.
Could 720p 48 be an attempt to address filmmakers? I wonder which would make for a better conversion: 720p 48 to 2K, or 1080p 24 to 4K?
Scott Anderson is offline   Reply With Quote
Old August 23rd, 2005, 10:30 AM   #12
Hmmm... ok. But how does a typical NLE handle all that information ? I mean its is different frames rates all , so how will the NLE interpret it ? wouldn't it need settings of different frame rates pre-installed to make it work ? I really can't grasp the concept for the NLE. It's not like under and over cranking film while it runs at 24fs to show 'slow-mo' and 'fast-mo' since the mechianism stays the same.
Sorry if this sounds stupid.
Do more, learn more
Old August 23rd, 2005, 12:17 PM   #13
Presumably you'll just be able to adjust the frame rate in the the interpretation rules for the file. It's all just simple software patching to do it properly. Pitch-shifting the audio may be the larger challenge.
-Steve
Steven White is offline   Reply With Quote
Old August 23rd, 2005, 12:28 PM   #14
Wesley, it's just like under-or-overcranking film. If you're shooting at these alternate frame rates, and them place them in a 24FPS timeline, you'll get an undercranked or overcranked shot. The DVCProHD Codec has a well-established workflow for this. The P2 format will also have additional metadata available that may include such things as framerate, f-stop, lens settings in addition to a date and time stamp, etc.
Basically any NLE that is capable of supporting DVCProHD and P2 will import the files natively, and be able to use the metadata contained in the MXF file on the P2 card.
Old August 23rd, 2005, 09:53 PM   #15
hmmm...
ok, I think I'm beginning to understand now.
another question :
So why do we need to pitch-shift the audio, when most of the time we don't want audio for overcrank (slow-mo) and undercrank (fast-mo) sequences ?
Do more, learn more
