Thread Tools
Search this Thread
Analog out questions..
Hi all,
Got a question on the HVX 200.. Do not own this camera, but will be working in a situation with it soon.. If you are shooting HD and want to use the Component output to grab the signal( it will be going to an AJA Ki Pro..) will composite output also have a signal available to it ?? (yes I know it will only be standard definition if it is there).. Just need to know if the signal will be available on both analog outputs at the same time.. Thanks so much !! |
