HVX 200 Zoom problem at DVinfo.net
Old February 28th, 2010, 02:32 AM   #1
I'm using a Panasonic HVX 200 at work and the zoom on the camera won't reach 55mm. It will go from the most wide angle to around 20mm. Has anyone experienced this before or can anyone recommend a good repair shop for the camera?
Eric Stemen is offline   Reply With Quote
Old February 28th, 2010, 07:07 AM   #2
There must be motor problem with the zoom lens then. If it is under warranty, send it back to Panny. Otherwise, someone from US can recommend a good repair shop then.
TingSern Wong is offline   Reply With Quote
Old March 1st, 2010, 02:12 PM   #3
Thanks for your response TingSern. It may be a motor problem, but the zoom won't reach all the way to 55mm in manual zoom mode either. A repair shop is probably the best idea.
Old March 1st, 2010, 08:13 PM   #4
Absolutely. You definitely need to send it back to a repair shop then. Good luck then.
