Variable frame rates? at DVinfo.net
Old April 18th, 2005, 04:57 AM   #1
Does anyone have further information on the vairable frame rates? If this is true, it would be fantastic :0)
Regards
Matt
Matt Harvey is offline   Reply With Quote
Old April 18th, 2005, 05:13 AM   #2
RED Code Chef
As far as I understand it, variable in the sense of:
NTSC: 24p/30p/60p
PAL: 25p/50p
Not variable in you can choose from a wider range than those above.
Rob Lohman, visuar@iname.com
Old April 18th, 2005, 07:37 AM   #3
NTSC: 24p/30p/60p
PAL: 25p/50p
I feared that might be the case.
It's "variable", not Variable.
Still, pretty good for getting some kind of slo-mo if mastering to 24p.
Carl Merritt is offline   Reply With Quote
Old April 18th, 2005, 10:51 AM   #4
You will get fast and slow motion with this however. I think what the camera will do is sample the 60p of 720p but record 30 or 24 onto the P2. This will give you a 50% or 40% slow motion which is the only camera in this price range to do that. Usually variable frame rates are only really used for slow motion anyways. How many of us say during shooting "You know I don't really like 50% slow motion but would rather have 61% slow motion.) I never really saw the use of variable rates in odd number vales. Maybe 45fps would be nice for a 75% slow motion for 30p or 48 fps for true 50% at 24p but everything else in between isn't very usefull.
Old April 18th, 2005, 11:52 AM   #5
Barry Wan Kenobi
It does give you true, legitimate variable frame rates, like the VariCam. It doesn't just sample at 60p, it'll sample and deliver whatever frame rate you choose.
The unanswered question is: what frame rates will it make available? It'll be more than just the 24/30/60 we know about, but we don't know yet the details on all the frame rates it will support.
Old April 18th, 2005, 12:07 PM   #6
Wow thanks again Barry! I really didn't think Panasonic would give us that at this cost. I still don't really see the use for it other than certain levels of slow motion but it is great that it is there.
Old April 18th, 2005, 03:32 PM   #7
You know what would be *really* cool? If you could shoot at 24fps and then ramp it to 60fps while it was recording for true speed ramps just like the film guys! Okay it would be a sudden ramp rather than a smooth transition, but cool all the same.
Simon Wyndham is offline   Reply With Quote
Old April 18th, 2005, 04:56 PM   #8
Simon, I think that, if Barry is correct and I assume he is, then it's better than that.
If it has true variable framerate then you will be able to do a ramp in camera, just as in a cine camera - although if not all speeds are supported (i.e. it only has 24/30/48/60 or something) then it'll still be a bit jumpy...
Dominic Jones is offline   Reply With Quote
Old April 18th, 2005, 08:48 PM   #9
OK, since nobody else wants to ask for some strange reason....
What are the max and min rates? Could we push the camera all the way to 100fps (or more) or is 60fps the max? Can we do rates as low as 1fps <maybe even lower than that> for setting up some time-lapse sequences (may be more handy than using a still camera).
Are rate changes dynamic, as in can the rate be modified or ramped up/down while recording? Can presets be assigned to alter aperture and exposure in accordance with fps? ooooh, wouldn't that be handy.
- Jeff Kilgroe
- Applied Visual Technologies | DarkScience
- www.darkscience.com
Jeff Kilgroe is offline   Reply With Quote
Old April 18th, 2005, 09:38 PM   #10
I know it's not the same, but you guys asking for variable frame rates solely for the purpose of smooth speed transitions should take a look at Vegas... it blows Premiere away in speed control. I use both... but Vegas rules on slowmo.
Also the thing I can't believe isn't mentioned more is the FOUR-CHANNEL audio... yeah, not two channels. FOUR.
Panasonic rules.
Matt Gettemeier is offline   Reply With Quote
Old April 18th, 2005, 09:39 PM   #11
Yeah Matt, four sounds nice, although we don't yet know if we can get four into the camera - it only has 2 XLRs ;)
Aaron
My Website
Meat Free Media
Aaron Koolen is offline   Reply With Quote
Old April 18th, 2005, 11:37 PM   #12
Barry Wan Kenobi
Regarding variable frame rates -- no hard and fast details have been released. However, on a slide at a presentation tonight, it said "4-60 fps", which leads me to think that the minimum will be 4fps, and the maximum 60, although we don't know how many speeds will be in-between.
Old April 19th, 2005, 01:00 AM   #13
Hey again Barry! Nice saying hi today.
I asked Jan about this earlier today, and she said that she was pushing for as many intermediate settings as possible for the variable frame rates. I could see at the very least there being a 48 fps between 30 and 60.
Charles Papert
www.charlespapert.com
Charles Papert is offline   Reply
